Author Topic: Mk2 Golf Gti  (Read 1793 times)
Offline keano
  • -Given: 79
Mk2 Golf Gti
« on: August 06, 2012, 11:14:22 pm »
Evening guys,
The past few months or so I've been plucking up the courage to blow invest some money in a little Mk2 8v Gti.
There are absolutely all sorts on the likes of ebay, gumtree and pistonheads. Ranging from 50p to £10k+.
Now I'm only looking to spend less than £1000 so obviously it's going to have some serious issues with regards to rust, and general 30year wear and tear!
Does anyone have any advice for an absolute novice retro car wanna'be owner? I don't want it to be a concourse show stopper, just a fun little run about :)
 :drinking:
Re: Mk2 Golf Gti
« Reply #1 on: August 06, 2012, 11:25:01 pm »
Lots of mk2 have loads of scene tax so are over priced so try not to fall into that game. Check the sills for rust and the chassis and if you can have a look behind the arches for rust, check the gearbox pull and drive smooth too and don't be afraid to ask the owner to jack the car up so you can get under it to check for rust and anything else also make sure the oil pressure lights are working as they should also make sure the plug leads to the oil filter housing are plugged in as they are for the oil pressure switch. Loads of other stuff too but mostly just what u should check in all cars
Offline keano
  • -Given: 79
Re: Mk2 Golf Gti
« Reply #2 on: August 06, 2012, 11:31:09 pm »
Cheers Mat!!  :drinking:
Yeah some of the 'scene taxed' cars actually make me laugh out loud with the prices. But each to their own I guess.
I've spotted this one so far...  :evilgrin:
Offline Gene Hunt
  • -Given: 59
  • -Receive: 61
Re: Mk2 Golf Gti
« Reply #3 on: August 07, 2012, 01:11:10 am »
Heater matrix(think thats what it's called?) can be a problem,lets go & covers the inside of the car with hot water!!!!!!.
Offline berg
  • -Given: 49
  • -Receive: 38
Re: Mk2 Golf Gti
« Reply #4 on: August 07, 2012, 02:31:37 pm »
i fancy an oak green 16v on a J plate.
maybe see if volkswizard can help you with a mint example?
Offline Scrubadub
  • Soon to be "bagged"
Re: Mk2 Golf Gti
« Reply #5 on: August 07, 2012, 02:43:37 pm »
The heater matrix was part of a VW recall. VW should of fitted 2 valves (1 black plastic and 1 silver alloy) on the water pipes that run through the bulk head to the matrix.
Fun bags
Offline gobbleplease
  • -Given: 64
  • -Receive: 48
Re: Mk2 Golf Gti
« Reply #6 on: August 07, 2012, 11:17:21 pm »
There are some good uns mate, but will probably need a fair bit work for that price ! If anyone was buying one for under a grand they would need to know how to fix things and be prepared to spend a bit of money ive seen a couple of decent / good examples for around £2500 and probably about the minimum spend if you dont want it to take up to much of your time.
Mine was around £1500 and its completely stripped to component form and needs alot of work doing, currently on hold until i get myself a welder as mat said sills are bad especially when people use self tappers to hold the trim on, fuel cap on mine was good but the filler neck holder is shot, both rear arches, spare wheel well, fuel pump hatch and battery tray all needs welding. On top of that i need wheel bearings, suspension, top mounts, all brakes really need replaced, all flexis, rear solid brake pipe, fuel tank straps, rubber window door seals, bushes fuel pump mounts, heater matrix, rocker gasket  and i could go on and on !!
Deffo something to think about before you buy !
MK7 GTI - ARRIVING DECEMBER
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
Re: Mk2 Golf Gti
« Reply #7 on: August 08, 2012, 09:02:17 pm »
^^^ I know that feeling, mine was pretty much the same and went from this: -
To this: -
And end up like this: -
Offline Deako
  • -Given: 38
  • -Receive: 44
  • Eat, Sleep....VAG
Re: Mk2 Golf Gti
« Reply #8 on: August 08, 2012, 09:39:18 pm »
Haha. Not if he wants to spend under £1k they can't!!
I've had 14 mk2s. Will have another!!!
#1493
Offline andrewparker
  • -Given: 32
  • -Receive: 78
Re: Mk2 Golf Gti
« Reply #9 on: August 08, 2012, 09:48:04 pm »
Do you think your Polo GTI is closer to the original Golf GTI ethos than the current car?
Offline Alexis
Re: Mk2 Golf Gti
« Reply #10 on: August 09, 2012, 12:25:15 pm »
I had a Mk2 8V Gti a few years back, I still miss it some days and like other people said I defo have another.
