Author Topic: Petrol in a jetta 2.0 tdi 140 (help)  (Read 1210 times)
Offline N44LED
« on: August 07, 2012, 02:27:05 pm »
Hi guys just got a phone call off my girlfriends mum saying that the cars cut out and just found out she's put petrol in it but only a tenners worth from quarter full.
Just wanted to know what needs to be changed to try and fix it I pretty know much the basics like drain the tank filters and drain the fuel lines just not sure how to drain the tank, lines and which filters  and if the injectors will need replacing or if we can try and get away with out changeing them.
Any help would be much appreciated
Thank you
Aled
« Last Edit: August 07, 2012, 02:28:46 pm by N44LED »
Offline Neiltdi
  • Full Hex+CAN
Re: Petrol in a jetta 2.0 tdi 140 (help)
« Reply #1 on: August 07, 2012, 02:54:38 pm »
could try filling it up with diesel and see how it goes? i know you can do it on old cars not to sure about new ones though
Full Hex+CAN in Hampshire.
Offline Horatio
  • -Receive: 39
« Reply #2 on: August 07, 2012, 05:17:14 pm »
I done this last year with my Bora PD130. Got it towed and had the tank pumped out as well as an egine flush. Used a few tanks of premium fuel and worked fine. I dont think I'd want to try putting more diesel in although other people I know have done this, stuck in some premium diesel and after two tanks of use has been fine. Not sure of the long term damage it may cause though???
Offline 56OctyVRS
  • -Receive: 72
« Reply #3 on: August 07, 2012, 06:14:10 pm »
Fill the tank full of diesel and it will be fine.
Offline N44LED
« Reply #4 on: August 07, 2012, 09:22:15 pm »
Thanks for the guys
Ye me mum did the same with our L200 just filled it up and it ran ok smoked a bit but then it sorted it's self out but just wondering with these if it would be the same thoe so think gunna change the filter drop the tank and clean the lines and hope for the best
