Author Topic: 1  (Read 1218 times)
Offline Beattie
« on: August 07, 2012, 06:25:56 pm »
« Last Edit: September 24, 2012, 09:05:14 am by CraigDavieBeattie »
MK6 2.0 GT Tornado Red.
Offline JoeDarKa
  • -Given: 57
  • -Receive: 73
Re: Steering wheel rubbing...?
« Reply #1 on: August 07, 2012, 06:58:22 pm »
Is it not the steering wheel itself? When i swapped mine over, it was catching / squeaking where it hit the steering collumn. I just put up with it until I changed it again for a flat bottom one
Offline JoeDarKa
  • -Given: 57
  • -Receive: 73
« Reply #2 on: August 07, 2012, 07:14:14 pm »
I dont think there are any differences. My wheel looked like it was tipped backwards slightly so was catching the top of the collumn
Offline JoeDarKa
  • -Given: 57
  • -Receive: 73
« Reply #3 on: August 07, 2012, 07:19:38 pm »
I didnt, I just put up with it until i changed wheels again unfortunately  :fighting: :fighting:
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
I'm sure that if you take the wheel off and the trim. And make sure that the trim is as far forward as it will go should sort it
Cluster and Key coding
Location Great Yarmouth
Offline john87
  • -Receive: 53
This happened with my first car (corsa) when I changed the wheel... it was the slip ring that was causing the squeak. It eventually stopped once the contacts got dirty enough  :grin:
Offline JoeDarKa
  • -Given: 57
  • -Receive: 73
Glad you have sorted it!  :happy2:
you can turn your radio back down now :signLOL:
