Author Topic: Revo K03 -> K04 upgrade sw options  (Read 2004 times)
Offline JMP
« on: August 10, 2012, 07:41:25 pm »
I have a revo stage 2 k03 GTI at the moment and Im looking at K04 upgrade options. Im thinking about changing to the k04 turbo and s3 injectors. But I dont want to change the pump and add more pressure to the cam, I have had zero problems with my fuelling and hopefully can keep it that way. It seems that most people change their pump during the upgrade, but since S3 shares the same pump, I would be happy with the power levels provided by the original pump. Does revo have sw for K04 conversion that can be used without the HPFP upgrade? So this would be pretty close to the K04 motor stage 2 file. Thanks for any info!
Offline edd666999
  • -Receive: 89
Re: Revo K03 -> K04 upgrade sw options
« Reply #1 on: August 10, 2012, 08:31:05 pm »
you would get the k04 file but just have fuel timing and boost turned down.
personally i wouldn't bother, the gain in power imo is out shadowed by the spool up time. I used to love the nippy k03, k04 feels sluggish...well untill you hit power later on then its  :driver:
« Reply #2 on: August 11, 2012, 10:49:21 am »
Revo stage 3 file requests 130bar so you'll need an uprated hpfp.
Offline edd666999
  • -Receive: 89
« Reply #3 on: August 11, 2012, 10:50:47 am »
Even with fuel on the lowest setting?
« Reply #4 on: August 11, 2012, 11:09:43 am »
yep...
Offline JMP
« Reply #5 on: August 12, 2012, 09:06:42 am »
Thanks for the input, maybe I will drive along with my K03 :)
