Author Topic: Snow Foam and Iron X  (Read 4144 times)
Offline nads1_uk
« on: August 15, 2012, 07:35:45 am »
I'm hoping to get my first snow foam lance and iron x delivered over the next day or so and I'm after a couple of pointers;
1  The car has never been snow foamed before - how long do I leave it on the car to dwell before rinshing off?  Do you just leave it to dwell or do you have a aggitate it?
2  How long do you leave the iron x on the wheels for?  If left too long does it cause any lasting damage?
Any other advice on using either of these 2 products would be appreciated as I haven't used either before.
Cheers in advance
Andy
Offline edd666999
  • -Receive: 89
Re: Snow Foam and Iron X
« Reply #1 on: August 15, 2012, 07:44:10 am »
im no pro detailer but i will tell you what i do/did
The snow foam i spray then do all the little bits while waiting for it to fall off the car, i wouldn't agitate it.
Iron x, once its doing its job it goes red, so i let it go red few more mins then washed it off. The instructions were very clear on the bottle and following those got me very good results. Oh btw, it stinks!
Offline nads1_uk
« Reply #2 on: August 15, 2012, 07:46:05 am »
Cheers for the quick reply and advice especially on the fact iron x stinks!
Andy
Offline Deako
  • -Given: 38
  • -Receive: 44
  • Eat, Sleep....VAG
« Reply #3 on: August 15, 2012, 08:12:43 am »
Not only does the actual product smell, but my driveway wreaked of rotten eggs mixed with sulphur for 4 weeks after I last used ironx. If I use it again, I'll drive my car on to the road an apply/rinse it there instead.
#1493
Offline nads1_uk
« Reply #4 on: August 15, 2012, 08:13:40 am »
Top advice - cheers
Offline Grande_GTi
  • -Given: 41
« Reply #5 on: August 15, 2012, 09:11:10 am »
http://www.detailingworld.co.uk/
Register to this, its a very resourceful forum and most things have usually been covered
instgram @ricky_grande
check out @lowlife_official
MK5 GTi OEM+
  • -Receive: 291
« Reply #6 on: August 15, 2012, 01:07:48 pm »
As long as it needs it. I go for longer in colder/winter climes and shorter duration in summer. Do not let it dry on. Doesn't need to be agitated but some people use a washmitt and agitate the whole car and rinse. I prefer to snowfoam and then use a raceglaze-style brush to clean all the lines and creases, badges, grilles etc. These are areas where dirt tends to get trapped. Once I've been round the whole car, I then power rinse and move on to 2BM wash. This rinse is where most of the dirt gets lifted and is for me the longest part of washing the car. Thoroughly rinsing means less contamination.
I'm sure it tells you on the bottle but generally 5 mins max. As with all products, can cause damage if left to dry on.
I would test out the foam lance settings and mixture settings first. Play around with the lance until you get a foam thickness that works for you. You only need about an inch of snowfoam in the bottle. I top up with hot water as I find it helps the snowfoam to cling better.
Iron-x is fairly straightforward.
Offline nads1_uk
« Reply #7 on: August 16, 2012, 08:16:04 pm »
Well my box of swag arrived today. Tried giving the car a quick going over with the snow foam. I turned the dial all the way to +. But didn't really get anything like the amount of foam I was expecting. Now this is no doubt down to me so any pointers would be great. I'm using the elite lance along with their snow foam
Andy
  • -Receive: 291
« Reply #8 on: August 16, 2012, 08:51:43 pm »
As I said, you have to adjust the settings. + means more air not more mixture. Also have to adjust the nozzle that the foam comes out of.
Offline nads1_uk
« Reply #9 on: August 16, 2012, 09:07:43 pm »
Thanks for your patience!!
I just assumed more '+' was more mixture. I'm going to do the wife's car at the weekend so I'll practise on hers  :evilgrin:
« Reply #10 on: August 17, 2012, 11:23:03 am »
Don't forget Iron-X can also be used on your bodywork to great effect!
Offline DFish
« Reply #11 on: August 17, 2012, 11:39:33 am »
if you got the large bottle on your snow foam gun then I'd go with about an inch of product at the bottom then fill to 3/4's with warm water. Never fill to the top as I've found you get less/softer foam.
Fish
Offline Padraig
« Reply #12 on: August 17, 2012, 10:56:40 pm »
I put 1inch of snow foam and fill the remainder with water,
But the snow foam never seems to cling to the car, in no time it just runs off, no matter which setting and even if i add more than 1inch of snow foam,
Are different brands of snow foam better than others?
  • -Receive: 291
« Reply #13 on: August 18, 2012, 07:22:48 am »
Yes. Autobrite magifoam seems to cling longer and more effective at cleaning.
Offline nads1_uk
« Reply #14 on: August 18, 2012, 08:35:45 am »
So is the elite snow foam not a good one?
