Author Topic: Hurdy's Golf .:R.  (Read 729169 times)
Offline Janner_Sy
  • -Receive: 113
Re: Hurdy's Golf .:R ...Loba turbo time....
« Reply #1725 on: August 12, 2013, 08:10:40 pm »
Was you running race fuel Dan? If not then the results between you and Hurdy seemed about right to me..
Weight difference was within 60-70kgs. Hurdy's car was running at pretty much it's limit on the day (fuelling etc) and gearboxes will play a huge part in the times - especially if your changes were as bad as you say they were Dan  :signLOL:
Don't forget Dans also has the flowed head etc for the full blown stage 3+ setup though.  I would have expected it to fly past Hurdys tbh.   What srt of time do stage 2+ K04s normally get?
Hurdy, were you on Racefuel as well?
« Reply #1726 on: August 12, 2013, 10:58:53 pm »
The fastest FWD K04 time is 16.6. Stage 2+ 4WD times are high 17's / low 18's in ideal conditions.
Yes, I was on Race fuel, but not to start with. My fastest pump fuel time was 16.7.
I would have expected high 14's to low 15's for a 450bhp car in ideal conditions.
Offline DanGB
  • Different
« Reply #1727 on: August 12, 2013, 11:07:41 pm »
DSG or manual?
Seat Leon Mk2 TFSI sport 4WD sleeper - Breaking
Buld thread: http://www.mk5golfgti.co.uk/forum/index.php/topic,45377.0.html
Offline Jussa
  • Bicester
« Reply #1728 on: August 12, 2013, 11:21:31 pm »
Still interested to see what your new 0-60 and quarter mile times are??  :party:
Offline Poverty
  • -Given: 36
  • -Receive: 21
« Reply #1729 on: August 12, 2013, 11:29:25 pm »
My TTRS @ 400hp did 14 secs at Marham 2 years ago
Offline Poverty
  • -Given: 36
  • -Receive: 21
« Reply #1730 on: August 12, 2013, 11:32:58 pm »
But the Evo has to change its gears manually and doesn't have constant boost throughout its runs
Also doesn't it depend if its a 5 speed or 6 speed box Evo?
The Evo also is less aerodynamic and creates downforce whilst the VAG's create lift.
Henry's Evo certainly wasn't struggling with his gearbox...  :surprised: :congrats: What power is it now Pov?
No one actually knows he tries to keep things secret, but I'd guess between 700-800hp he runs a gtx3582 with a 50/50 meth mix. When he used to run a non billet turbo like dan gt35 at 650hp his car was "slow" due to lag and poor transient response between gear changes. A billet wheel makes a massive difference
Offline Jussa
  • Bicester
« Reply #1731 on: August 13, 2013, 12:04:55 am »
So your 400hp TTRS took 2 seconds off John???  :confused:
Offline Poverty
  • -Given: 36
  • -Receive: 21
« Reply #1732 on: August 13, 2013, 12:36:46 am »
It wasn't as windy that day but looking at the other TTRS on the day that was also dsg it was just over 2 secs faster @ 400-420bhp
« Reply #1733 on: August 13, 2013, 12:50:54 am »
DSG or manual?
high 14's for DSG and low 15's for manual. :smiley:
Offline Sunglasses Ron
« Reply #1734 on: August 13, 2013, 10:34:10 am »
So the RF and race map only knocked off 0.4 secs?!?!  :confused: I'd of expected a lot more than that tbh mate, otherwise it's hardly worth bothering with given the expense, surely?
« Reply #1735 on: August 13, 2013, 10:53:07 am »
Highest manual for the day this year was 15.6 on a APR Stage 2 car (SSECKHAM - 68). He even managed to beat the same spec S-tronic car by 0.1 secs too  :confused:
Shows what difference the wind made. I estimate it gave around 1.5 - 2 secs handicap around that area (14-18 secs). Let's also not forget that we are comparing times in March (8-10oC) to times in August (20-22oc) too..
My car now has a Forge cooler over last year, but hasn't yet been mapped to suit (just ECU adaptation). Although my time was over a second slower, my terminal speed was identical, so I assume it has made a difference somewhere given the wind that day...
« Last Edit: August 13, 2013, 10:56:19 am by Sunglasses Ron »
Offline Poverty
  • -Given: 36
  • -Receive: 21
« Reply #1736 on: August 13, 2013, 10:56:41 am »
Apparently that particular s-tronic driver is a bit of a pansy lol. Should have put more runs in but the other ttrs's incident put him off :/
But yeah on a good day, a TTRS s-tronic should be doubt it in the 13's so about 2 secs down as you say
« Last Edit: August 13, 2013, 10:58:33 am by Poverty »
Offline Statller-Stevo
« Reply #1737 on: August 13, 2013, 11:18:37 am »
Ben, John ran the same boost with a mix of VP + 99
I'd guess 20-25 hp more max & 15-20 ft-lb more with the RF at the same boost pressure so the times not that bad really
If you had a bigger turbo that could blow another 10psi of boost with the RF then expect much more maybe up to 60-80hp
I see 30whp more on my Loba car with the RF and a tiny bit more boost
You know John every 0.1 creates a bigger bulge :grin:
« Reply #1738 on: August 13, 2013, 11:26:35 am »
Every 0.01 Steve. :signLOL:
« Reply #1739 on: August 15, 2013, 06:43:20 pm »
Update.....
Did a few runs using the Dynolicious app. Using 99ron without WMI.
Each way runs were almost identical.
