Author Topic: Hurdy's Golf .:R.  (Read 727774 times)
Offline vRSAlex
  • -Receive: 253
Re: Hurdy's 500+bhp Golf .:R
« Reply #2565 on: May 25, 2014, 03:07:03 pm »
Defoo keep the lambo logo! You planning anything for the rears?
Yes, I'm going with some TTRS 335mm rears. Keeping the OEM calipers, but painted and swapping the carriers to fit.  :happy2:
TTRS rears are 310 and a different offset.  They only fit on TTRS hubs.
Follow AKS tuning on Facebook
Offline N8KOW
  • Detailer - 2014
    • Kowalski Details
« Reply #2566 on: May 25, 2014, 04:52:46 pm »
335mm rears are RS6 AFAIK, theres a set of Phaeton discs that work too, Dave has carriers I believe.
2014 Mk7 Golf R on Order...
Offline Janner_Sy
  • -Receive: 113
« Reply #2567 on: May 25, 2014, 06:58:04 pm »
Yes,
but its not a lambo lol.  Id get an R logo or brembo//AP/Alcon or what ever they are.
They do look awesome in Yellow though.  What size discs?
« Last Edit: May 25, 2014, 06:59:37 pm by Janner_Sy »
« Reply #2568 on: May 25, 2014, 07:01:02 pm »
 Err, rear carriers are TTRS ( all same carrier on TT's ) and rear discs are A8/Phaeton. Also same on 2007 S6's, V10's etc.
Offline Jussa
  • Bicester
« Reply #2569 on: May 25, 2014, 07:28:51 pm »
John, change those TD centre caps for VW ones  :happy2:
I did it on mine for Audi ones and they look the nuts  :drinking:
« Reply #2570 on: May 25, 2014, 08:20:42 pm »
Yes,
No, it is quicker than a Lamborghini.  :wink:
Off hand I don't know the diameter.
Offline taylor
« Reply #2571 on: May 25, 2014, 08:29:15 pm »
Them brakes are truely something else keep them as is mate
Tornado red ED30
Offline Janner_Sy
  • -Receive: 113
« Reply #2572 on: May 25, 2014, 09:51:14 pm »
Yes,
Still not a Lambo though  :innocent:  IMO its like a normal GTI putting on an Ed30 badge or an R badge
« Reply #2573 on: May 25, 2014, 09:51:27 pm »
They are staying exactly as they are.   :happy2:
« Reply #2574 on: May 25, 2014, 09:59:39 pm »
Not quite Sy, although everyone is entitled to their opinion and in this case it is mine that counts.  :P
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=m4l9vcie12b2a5nov81i7uep3p&/topic,19740.0.html
« Reply #2575 on: May 25, 2014, 10:03:28 pm »
Well what about all the guys who use RS (TTRS RS3 etc) calipers on GTIs... should they remove the RS as its not an RS. If Hurdy wants the kudos of Lamborghini decals on his RS4 calipers then so be it.  :happy2:
Offline Janner_Sy
  • -Receive: 113
« Reply #2576 on: May 25, 2014, 10:04:14 pm »
Very true  :happy2:
Yep  :innocent:
« Reply #2577 on: May 25, 2014, 10:34:33 pm »
To get back on topic......
The HPA lower engine mount I had fitted is mUCH better than the THS one I had fitted beforehand. The NVH has been substantially reduced and is definitely one mod I can recommend. Statller supplied mine as they are now the UK HPA outlet.
The larger throttle body definitely helps lower the rpm that the turbo starts to spool up.
The "Lamborghini" brake upgrade set-up works very well. Hauls down from speed impressively. I spoke to Steve Jr as he had a similar set-up on his Edition 30 and he said that after 8,000 miles of mixed use his Pagid RS blues only had 30% wear on them which should allay fears that the OEM master cylinder may increase wear.
The RS4 injectors are proving more than up to the task of providing the fuel for my current 500+ bhp. My future plans will mean I will need much more fuel so either bigger injectors or a secondary fuel rail.
Next week I'm back at Nortech for some more changes.
Also next week I'll be fitting up the carbon fibre rear spoiler and front splitter.
Target for this summer is to get into the tens on the 1/4 mile, a few trackdays to prove the set-up is solid, much more VCDS logging and continuous speed testing for reference.
« Reply #2578 on: May 25, 2014, 10:38:17 pm »
Injector flow?
Stock = 1080 cc/min
RS4 = 1091 cc/min
S3 = 1217 cc/min
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
« Reply #2579 on: May 25, 2014, 10:44:02 pm »
I'm rocking S3 badged calipers on my ED30, it's all part of the look Sy  :P
Hurdy - when is the engine build?? Or have I missed it?  :laugh:
« Last Edit: May 25, 2014, 10:45:36 pm by GrayMK5GTI »
