Author Topic: Hurdy's Golf .:R.  (Read 725115 times)
Offline dan930
  • -Receive: 56
Re: Hurdy's Golf .:R.
« Reply #2970 on: June 30, 2015, 11:41:34 am »
Out of those, which clutch packs would you go for? I'd think about HPA so I can also get their big trubo and inlet upgrades as well.
I think steve jnr from Stattlers are using dodson clutch packs on his mk6R
MK6 golfR dsg
AKS TUNED
NORTECH PERFORMANCE HTA3071
R TECH custom map
« Reply #2971 on: June 30, 2015, 12:34:30 pm »
Depends on your ultimate power/torque target.
If you are seeking 500+ lbft then go for HPA/HGP.
Up to 500lbft then Dodsons.
Offline th3_f15t
  • -Receive: 183
« Reply #2972 on: June 30, 2015, 02:01:14 pm »
Well, I'm lead to believe that for up to stage 2+ (so around 360-380bhp), the stock setup will be able to cope well enough.
Offline Eddie07
« Reply #2973 on: July 02, 2015, 11:27:40 pm »
More than enough.
Offline th3_f15t
  • -Receive: 183
« Reply #2974 on: July 03, 2015, 07:20:51 am »
Not that my "definitely will stay stock" new daily will get a stage 2+ upgrade... Damn you Hurdy! :mad:
Offline joms6r
  • My Ride: Golf 6R
« Reply #2975 on: July 07, 2015, 03:52:20 pm »
Thought i'd share this on here, managed a run against Hurdy Saturday just gone at Inters:
Please ignore my terrible shifts, was my worse run on the day and think I got a bit carried away trying to keep up lol
R-tech powered Mk6 Golf R
** Mk5 GTI Track build: >>Here<< **
Offline teo_parvu
  • -Given: 30
  • -Receive: 57
« Reply #2976 on: July 07, 2015, 04:05:34 pm »
Rocket!  :happy2:
...and yours is not a slow car.  :signLOL:
Offline joms6r
  • My Ride: Golf 6R
« Reply #2977 on: July 07, 2015, 04:26:14 pm »
Haha yeah! It was my worse run of the day, a 14 something.
« Reply #2978 on: July 18, 2015, 08:42:44 am »
Thanks for the vid  :happy2:
« Reply #2979 on: July 18, 2015, 08:43:32 am »
GTI International, Saturday and bagged the VW4WD trophy.   :smiley:
Quickest time was 11.20 and fastest terminal was 126.03mph.
Full weight, spare in, suitcase in, laptop in, 3/4 tank of 99 Ron onboard and a big fat driver in the seat!   :laugh:
Good points...
New map saw a better terminal when the boost was dialled up for one run.
car runs creamy smooth.
Bad points...
New DSG map has a lower launch limit, which needs turning up to bring my 60' times back down under 1.85 seconds.
The new map is so good I am slipping the clutches even more!
On Sunday I ended up as the runner up in the VW4WD section as I did two lower boost runs early on (11.32@122) and then parked the R up to enjoy the day. Had lunch and decided to up the boost and get some lower times (with the settings I was on with my best run on Saturday) but sadly the weather had other ideas. :sad1:
Offline th3_f15t
  • -Receive: 183
« Reply #2980 on: July 18, 2015, 01:13:26 pm »
Been tempted to try a run with everything out, including the back seats? See what the very limit of your engine can do?
« Reply #2981 on: July 18, 2015, 05:14:13 pm »
Not on the new mapping. Best to date has been 11.02.
Offline Jussa
  • Bicester
« Reply #2982 on: July 19, 2015, 04:03:57 pm »
Change your best terminal in your signature  :happy2:
« Reply #2983 on: July 22, 2015, 09:33:27 pm »
Now in the cars for sale section.
Offline AJP
  • -Given: 392
  • -Receive: 316
« Reply #2984 on: July 22, 2015, 09:47:52 pm »
The end of an era! Going for an S4 then?
Was a pleasure meeting you a few weeks ago at Statller by the way. (Red GTI 3dr in for dv, pcv and cam follower).
And the car is phenomenal. Never been in anything quite like it. It'll make someone very happy.
