Author Topic: Hurdy's Golf .:R.  (Read 729620 times)
Offline Cupra R
  • -Given: 18
Re: Hurdy's Golf .:R
« Reply #870 on: November 23, 2012, 06:57:04 pm »
Update......
Ordered all the suspension goodies in one go! :evilgrin:
 :driver:
I'm hoping the car will be more stable than that smiley with the suspension mods on :laugh:
Ordered/stashed ready to go on......
Bilstein B16 PSS10's
Whiteline heavy duty droplinks
Powerflex full polybush front and rear kits
Whiteline Anti-lift Kit
H & R Front and rear ARB's
THS engine mounts.
Hmmmm brakes? :party:
Couldn't of picked them better myself John  :happy2: :driver:
Offline vRSAlex
  • -Receive: 253
« Reply #871 on: November 23, 2012, 07:01:46 pm »
Just needs some Ground Control top mounts (and swap the pflex for superpro!)  :P
Follow AKS tuning on Facebook
Offline Cupra R
  • -Given: 18
« Reply #872 on: November 23, 2012, 07:06:38 pm »
One day I will get some of these fitted   :happy2:
Offline danishmkvgti
  • -Given: 243
  • -Receive: 154
« Reply #873 on: November 23, 2012, 07:10:06 pm »
The list clearly shows that all the info on this forum has be used to select the perfect parts for your car John, i would chose the same parts for a new build  :congrats:
Brakes look no further than LOBA  :innocent:
Regarding rears, do you want 330mm 2 piece rears or 350mm 2 piece rears??
Utilizing the standard rear caliper and pads  :happy2:
Yes, I've done some extensive investigations before pulling the trigger - as I will with the brakes.
OOOOOOOOOH, those rears look the biz.
I'm guessing lighter than OEM too. May look into lighter calipers too. :smiley:
Not much idea in going lighter in the rear are there, if you want that approach you should locate the aluminium rear subframe for the 4wd, Michel Dammfors has that on his cupra.
Over the top mod list ;o)
Offline vRSAlex
  • -Receive: 253
« Reply #874 on: November 23, 2012, 07:20:32 pm »
The top mounts are leaving the US next week Rich.  I can add another set for you John?
Offline DaveB@Vagbremtechnic
  • Trader - 2014
  • -Receive: 130
    • Vagbremtechnic.com
« Reply #875 on: November 23, 2012, 07:25:26 pm »
I'll take your single piston rear brakes with a larger disc..... (Soooo 2011 by the way....)
And raise you 4 piston rears, separate handbrake Caliper choice of two setups
Boxster rears separate handbrake Caliper. RS6 rear disc
Audi R8 setup 355x32mm
R8 rear ceramics on an Edition 30 anybody??.?
Currently its expensive due to the components used but I'm working hard to make it affordable by using more cost effective components. The current first batch of 9 sets are all sold already, might take 9 months but there's a chance of getting this on R32s and S3s for three figures.
All the kits are going on 400BHP Plus TT's and a very special Bi turbo R32
Would love to see this more commonly used though, the pedal feel is sublime
  • -Given: 243
  • -Receive: 154
« Reply #876 on: November 23, 2012, 07:33:21 pm »
Your kits will beat all other all the time Dave  :notworthy:
All three set are great and i would love one of those on my own old car.
I assume the ceramic kit won't reach the 3 figure category, and i assume the R8 setup is a mock up?? Otherwise your get tired trying to bleed it  :signLOL:
« Last Edit: November 23, 2012, 07:35:48 pm by danishmkvgti »
« Reply #877 on: November 23, 2012, 07:35:26 pm »
You're right, completely missed those. I'm on it!
  • Trader - 2014
  • -Receive: 130
« Reply #878 on: November 23, 2012, 07:37:21 pm »
First one out of the box jake.
  • -Given: 243
  • -Receive: 154
« Reply #879 on: November 23, 2012, 07:45:37 pm »
Since i saw the R8 rear solution for the first time i have wanted the twin caliper rear setup for the golf, we need to meet so i can buy you some pints Dave  :wink:  :drinking:
« Reply #880 on: November 23, 2012, 07:45:42 pm »
Keep posting the brake porn up Dave, my juices are starting to flow :ashamed: :grin:
  • Trader - 2014
  • -Receive: 130
« Reply #881 on: November 23, 2012, 07:50:12 pm »
Dave B's Secret Brake Hit List...
Gazbut S3 DONE Oct 2012  :pomppomp:
Hurdy........ :wink:
Think I owe you a beer and a PM Jake...off to the shed outside, give me 5 mins
« Reply #882 on: November 23, 2012, 08:08:48 pm »
 :signLOL:
« Reply #883 on: November 23, 2012, 11:56:01 pm »
A few shots of the R seeing as I'd given her a clean and the weather was good.  :smiley:
Offline paulk
« Reply #884 on: November 24, 2012, 12:03:37 am »
looking pretty tasty now mate ....i fancy some 18s but needs lowering first
