Author Topic: Hurdy's Golf .:R.  (Read 729785 times)
Re: Hurdy's Golf .:R
« Reply #915 on: November 27, 2012, 05:30:11 pm »
is this what you were looking for John?
http://www.rri.se/index.php
That's the one. :smiley:
« Reply #916 on: November 27, 2012, 05:51:14 pm »
I quite fancy getting mine on a hub dyno at some point.  IS it in sheffield?
I know one in Doncaster Sy
Offline Cupra R
  • -Given: 18
« Reply #917 on: November 27, 2012, 06:03:46 pm »
AET is in Normanton, just off the M62.
Offline jmccullough160
« Reply #918 on: November 27, 2012, 10:20:34 pm »
Lovely R mate
Offline Oli
  • -Given: 19
  • living the dream....
« Reply #919 on: November 28, 2012, 02:05:02 pm »
Are you still on the standard IC?  Am I right in thinking this is the same as the one in the GTI/ED35?
www.bmvs-camperhire.co.uk - Brand new VW California SE rental
« Reply #920 on: November 28, 2012, 06:11:06 pm »
Golf R has the S3 intercooler with plastic end tanks. Bigger than the GTI cooler.
Offline Oli
  • -Given: 19
« Reply #921 on: November 28, 2012, 07:25:53 pm »
To be fair thats what I thought, bit I read it was the same on an American forum.......
« Reply #922 on: December 04, 2012, 05:53:57 pm »
Update.....
Booked in next week for all the suspension doing plus engine mounts and alloy front arms.
Also at the same time the water methanol injection goes on.
Be rude not to wouldn't it.  :laugh:
I did have a sneaky conversation about having nitrous again, but this time purely for the 1/4 mile runs :rolleye:
Not sure yet though as it would involve internals/HPA clutchpacks etc, but I guess those may be done at some point anyway! :evilgrin:
« Reply #923 on: December 04, 2012, 06:15:23 pm »
"I'm doing the mods individually so I feel the effect and or benefit of each" sounds familiar?  :grin:
Offline Janner_Sy
  • -Receive: 113
« Reply #924 on: December 04, 2012, 07:28:16 pm »
brilliant  :grin:  Will it be like last time, start with a 25hp injector then think stuff it and bolt on the 100Hp injector then hold on for dear life  :driver:  At least with the R you will have traction so a 100hp shot would give an immense improvement in time up the strip.  Even a minor 25Hp injector would be a pretty substantial gain i think.
Which alloy front arms?  I thought th R would have had the alloy arms as std because of the bigger brakes, like on the S3.
Same WMI kit as in the Polo?
« Reply #925 on: December 04, 2012, 08:30:43 pm »
 :ashamed:
Well, when you can get all the parts in one go on "Black Friday" at Awesome it would have definitely been rude not to. I reckon the savings alone on the suspension parts will pay for the WMI.
 :laugh:
« Reply #926 on: December 04, 2012, 08:34:24 pm »
The R definitely has the "pig iron" arms as we had a look when the exhaust was fitted. Quite surprised myself that the R doesn't have these as stock considering the list price of a new R v's S3.
I think it will probably end up as a BT conversion before the nitrous, but that is what discussions are for.......to contemplate and weigh the options up. :happy2:
Offline geordie56
« Reply #927 on: December 04, 2012, 08:35:26 pm »
Sy none of the vw's have alloy arms pal it's a scandal. The only thing anywhere near is the rocco with alloy rear hubs. You want to go for the TT alloy front hubs aswell while you're on John, may aswell, lot less unsprung weight and the centre of gravity sits correctly as the ball joint is in the correct position by doing this. It's out by around 35-40mm with just the arms as the steel hub sits higher up and the ball join has to go on the wrong side of the arm as a solution. :happy2:
« Reply #928 on: December 04, 2012, 10:19:46 pm »
Doesn't the hub affect the offset Shaun?
Offline geordie56
« Reply #929 on: December 04, 2012, 10:38:38 pm »
It does pal but if memory serves me correct only by 10mm what is the standard offset on the R and what offset are you running on the TD's
