Author Topic: Should I change my coilpacks?  (Read 1766 times)
Offline E30Dom
  • -Given: 42
  • -Receive: 76
« on: August 16, 2012, 01:55:11 pm »
Hi Peeps,
My coilpacks have the production date of 10/06... My car is in for a service on the 8th September, is it worth updating them...
Ideally I'd like the red ones, i will search for the part number unless anyone has to hand?
Cheers,
Dom
Diesel Daily Hack.
Re: Should I change my coilpacks?
« Reply #1 on: August 16, 2012, 02:15:28 pm »
Do you know the version number, it's on the underside of the coil pack.
If you are lucky, you may be able to have them replaced FOC by VW if you're in the coil pack recall group so ring your VW service department and ask before buying.   :smiley:
Offline E30Dom
  • -Given: 42
  • -Receive: 76
« Reply #2 on: August 16, 2012, 02:21:30 pm »
Thanks bud, I asked at my first Main dealer service whether there was any recalls outstanding on the car and the girl said no, so just left it.... but if they were produced in October 2006, surely they won't be the latest revision?
Not sure how to remove to look tbh.
Do fancy some red ones now though  :signLOL:
Diesel Daily Hack.
« Reply #3 on: August 16, 2012, 02:34:06 pm »
Yup, your coilpacks if unchanged will be a few revisions behind the latest version.
You can get the red ECS ones from http://www.awesomegti.com/car/vw/golfmk5/red-ignition-coil-pack-set-2-0tfsi
Removing the coil packs if you have the engine cover off is quite easy and needs no special tools.
Offline E30Dom
  • -Given: 42
  • -Receive: 76
« Reply #4 on: August 16, 2012, 02:38:41 pm »
I'm not running a engine cover at the mo, how do the coilpacks come off?
Diesel Daily Hack.
Offline Tortaruga
  • -Given: 36
  • -Receive: 105
« Reply #5 on: August 16, 2012, 02:44:58 pm »
Unclip the coil pack harness (4 electrical connectors).
Pull the packs up. I used a pair of zip ties under the head of each one - give them a wee wiggle and coax them up - easy!
'07 Red manual
Offline GarethB
« Reply #6 on: August 16, 2012, 03:06:43 pm »
They are really easy to get out Dom - won't cause you any drama at all  :happy2:
Offline E30Dom
  • -Given: 42
  • -Receive: 76
« Reply #7 on: August 16, 2012, 03:11:27 pm »
Haha you reckon! I've given up working on cars... though my Rev G DV has turned up today lol
Diesel Daily Hack.
Offline GarethB
« Reply #8 on: August 16, 2012, 04:49:39 pm »
Get it on!
Offline E30Dom
  • -Given: 42
  • -Receive: 76
« Reply #9 on: August 16, 2012, 04:58:24 pm »
Get it on!
Are you using one G?
Diesel Daily Hack.
« Reply #10 on: August 16, 2012, 05:18:03 pm »
You can get the latest revision AND/OR the red ones from Alex at AKS  :happy2:
Offline E30Dom
  • -Given: 42
  • -Receive: 76
« Reply #11 on: August 16, 2012, 05:29:34 pm »
Have emailed him... ;-)
Diesel Daily Hack.
« Reply #12 on: August 16, 2012, 05:42:49 pm »
I might order some red ones for a bit of bay bling  :innocent:
Saintsteve
« Reply #13 on: August 16, 2012, 06:35:40 pm »
Hi Peeps,
Cheers,
Dom
I'm sure your car should of been part of the coil pack recall, if your car is 07 and prior , if it's 57 and on, it wasn't AFAIK.
Check with another Stealer Dom.
Offline GarethB
« Reply #14 on: August 16, 2012, 07:57:21 pm »
Get it on!
Recently switched from a D to a G on the K03.
However, I'm so concerned about the new rubber diaphragm splitting under the heat of the K03, that I seem have purchased a K04  :signLOL:
