Author Topic: 18x8j et20 fronts and 18x8j et 24 rears?  (Read 1529 times)
Offline tommygti
  • -Given: 22
« on: August 18, 2012, 11:51:42 pm »
As above, Will these wheels fit? If not can there be any work done to make it happen, e.g. Arch rolling. Cheers
Offline sub39h
  • -Given: 189
  • -Receive: 84
Re: 18x8j et20 fronts and 18x8j et 24 rears?
« Reply #1 on: August 19, 2012, 12:09:27 am »
offset is too low mate. on Mk5s Bentley rims sit about flush and they are 9J ET41
9J ET 41 sits the same as 8.5J ET35 or 8J ET29
in other words, compared with 8J ET20 and 8J ET24 the rims will poke by 9mm and 5mm respectively. arch rolling won't make any difference if the wheel is outside of the arch in the first place. there may be enough metal at the back of the wheel to machine down and increase the offset, but i would contact a reputable wheel refurbisher and ask them first.
short of that it's a no go i'm afraid.
PLANS: Stage 2+
Offline higher1
« Reply #2 on: August 19, 2012, 12:56:29 am »
Way to low offset the fronts will sit out 37mm more than a standard monza and rub the arch !
Ah-exclusive custom ultra low H&R Coilovers 110mm, ITG induction kit, 18" super RS's, USA rear bumper, USA front grille with smooth number plate surround,recaro bucket seats. now sold !
mk1 golf 1.8 20v turbo
Offline tommygti
  • -Given: 22
« Reply #3 on: August 19, 2012, 01:24:44 am »
So a 100% NO! Between now and the 1st post I've changed my mind and found my new wheels anyway. Cheers for the help.
Offline sub39h
  • -Given: 189
  • -Receive: 84
« Reply #4 on: August 20, 2012, 11:39:56 am »
you need to post them in the for sale section
PLANS: Stage 2+
