Author Topic: Xenons fitted - fault codes - left hand light not working at all now  (Read 4307 times)
Offline fab5freddy
  • -Given: 238
  • -Receive: 239
Fitted on Friday and came up with the below, had to pick it up from the garage as needed the car for the weekend, worked fine that evening, just dash warning sign
4 Faults Found:
02498 - Left Low Beam Reflector Motor (V294)
            012 - Electrical Fault in Circuit
             Freeze Frame:
                    Fault Status: 01111100
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 107
                    Mileage: 69616 km
                    Time Indication: 0
                    Date: 2005.09.13
                    Time: 31:63:63
             Freeze Frame:
                        ON
                    Voltage: 13.40 V
                        ON
                        ON
                        OFF
                        OFF
                        ON
02499 - Right Low Beam Reflector Motor (V295)
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 107
                    Mileage: 69616 km
                    Time Indication: 0
                    Date: 2005.09.13
                    Time: 31:63:63
             Freeze Frame:
                        ON
                    Voltage: 13.40 V
                        ON
                        ON
                        OFF
                        OFF
                        ON
00978 - Lamp for Low Beam; Left (M29)
            010 - Open or Short to Plus - Intermittent
             Freeze Frame:
                    Fault Status: 00101010
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 146
                    Mileage: 69616 km
                    Time Indication: 0
                    Date: 2005.09.13
                    Time: 31:63:63
             Freeze Frame:
                        ON
                    Voltage: 13.40 V
                        ON
                        ON
                        OFF
                        OFF
                        ON
00979 - Lamp for Low Beam; Right (M31)
             Freeze Frame:
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 146
                    Mileage: 69616 km
                    Time Indication: 0
                    Date: 2005.09.13
                    Time: 31:63:63
             Freeze Frame:
                        ON
                    Voltage: 13.40 V
                        ON
                        ON
                        OFF
                        OFF
                        ON
Last night popped out and the left hand light has stopped working all together  :sad1: got this code now
1 Fault Found:
02394 - Parking Light Left Front (M1)
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 107
                    Mileage: 69644 km
                    Time Indication: 0
                    Date: 2005.09.13
                    Time: 31:63:63
             Freeze Frame:
                        ON
                    Voltage: 14.00 V
                        ON
                        ON
                        OFF
                        OFF
                        OFF
Now it's due back into the garage on Tuesday anyway as in fairness the lads had ran out of time with the weekend looming and were due to sort the fault codes, but both lights were working fine when i collected it
Has anyone come up against this before? Just looking for a bit of reassurance that the lights aren't fubar  :happy2:
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
Re: Xenons fitted - fault codes - left hand light not working at all now
« Reply #1 on: August 19, 2012, 04:21:09 pm »
I had a similar problem when I retrofitted xenons, turned out to be a broken wire in the loom
Cluster and Key coding
Location Great Yarmouth
Offline fab5freddy
  • -Given: 238
  • -Receive: 239
« Reply #2 on: August 19, 2012, 04:33:08 pm »
Cheers Eddie, thats what i was hoping. Bought of ebay and just paranoid i've bought a dud set  :sick:
Was it an easy fix on the wire or did you get another one?
Offline fab5freddy
  • -Given: 238
  • -Receive: 239
« Reply #3 on: August 21, 2012, 06:02:39 pm »
Just to update this, turned out to be a bad earth connection inside the headlight
All working perfectly now  :smiley:
Offline sanj
  • -Given: 17
« Reply #4 on: August 25, 2012, 08:03:49 am »
Glad to hear it,nothing worse than thinking you bought a faulty set! :smiley:
