December 24, 2024, 01:34:31 am
All Things Mk5
Technical Workshop
Mk5 Gti brakes on a mk5 1.9 tdi
Topic: Mk5 Gti brakes on a mk5 1.9 tdi (Read 2176 times)
foxyp
Can't Read PM's Yet!
-Given: 0
-Receive: 0
August 21, 2012, 08:46:32 pm »
Evening, does anyone know if gti brakes can just bolt onto the tdi hubs or do I have to get gti hubs like on a mk4?
If so could anyone please tell me which hubs i can get?
any help would be great
Rob
RENNTAG
Won't Shut up.
-Given: 15
-Receive: 23
Premium Performance Parts
Re: Mk5 Gti brakes on a mk5 1.9 tdi
Reply #1 on:
August 21, 2012, 08:55:21 pm »
Pretty sure they will go straight on to the standards hubs.
Some people just put the GTI carriers on as i think the actual caliper is the same. The carrier just allows you to run a bigger disc.
foxyp
-Given: 0
-Receive: 0
Reply #2 on:
August 21, 2012, 10:08:53 pm »
I had alook tonight, It looks like the carrier is part off the hub :( has anyone done this conversion?
skard
Just look at my post count
-Given: 5
-Receive: 245
My Ride:
Reply #3 on:
August 21, 2012, 10:11:44 pm »
You'll need to change the hubs on a 280mm disc 1.9TDI, it is the 2.0 TDI with 288mm discs that uses the same calipers but different carriers to a GTI.
danishmkvgti
-Given: 243
-Receive: 154
My Ride:
Reply #4 on:
August 22, 2012, 06:51:54 am »
both hubs and front suspension needs changing, your hubs uses 50mm struts and the ones on the 2,0 TDI with 288mm discs has 55mm as the gti and all the other Mk 5, it's up hill mate
Over the top mod list ;o)
foxyp
-Given: 0
-Receive: 0
Reply #5 on:
August 22, 2012, 09:35:41 pm »
Thank you for all the help... Looks like I'll have to get the hubs and wait till I get my new suspension :)
All Things Mk5
Technical Workshop
