Author Topic: **HOW TO**: Door lock module replacement **Photos Fixed**  (Read 91474 times)
Offline doylebros
Re: **HOW TO**: Door lock module replacement
« Reply #60 on: January 04, 2016, 05:07:17 pm »
It's more than a little more - in the region of £100 more.
I've fitted plenty and have only one faulty one,which the supplier changed without any questions.
It's not a difficult job but easy to get wrong without using a how to guide.
My advice would be to have it scanned with VCDS and do some output testes to prove its the module and not the door wiring from the pillar.
Offline tlnds
« Reply #61 on: January 05, 2016, 01:46:12 pm »
Cheers I'll probably scan it and try to narrow it down first then
Offline Berry
« Reply #62 on: January 30, 2016, 08:05:21 pm »
Did this Job today, all went smoothly. Just a little note to everyone else, when you 'pull the handle' after first loosening the T20-it may need a bit more of a firm pull than you think. Apart from that, great guide thanks Matto!
Shadow Blue MK5 GTI
Offline Spooky211
« Reply #63 on: March 09, 2016, 08:38:32 pm »
Looks like my passenger door module is starting to play up. When I try to open the door from the inside you can hear and feel something clicking but it won't open, is this similar to what you guys had? Certainly feels more mechanical than electrical anyway.
Also, is there anyone with VCDS in or around Glasgow that would be willing to scan my car for me? Will pay with beers!!
« Last Edit: March 09, 2016, 08:45:02 pm by Spooky211 »
Offline Spooky211
« Reply #64 on: March 10, 2016, 11:59:42 am »
Anyone?  :smiley:
Offline Berry
« Reply #65 on: March 10, 2016, 01:46:55 pm »
Yep that sounds about right to be honest mate.
It's best to check and make sure what codes are being thrown but I didn't as all the evidence was pointing to door lock module so risked it. Been spot on ever since.
Shadow Blue MK5 GTI
Offline Spooky211
« Reply #66 on: March 10, 2016, 02:28:10 pm »
Cheers mate!
What a pain.....just need to find someone with Vagcom!
Offline pjuster
« Reply #67 on: March 17, 2016, 03:49:47 pm »
top guide, only things that I can add is..
my door skin was well and truly stuck near one bolt, yet the bolt was out, I checked and double checked all screws were removed, in the end I put my arm between the glass and door skin and shove it outwards where it was stuck (with one tiny blob of black sealant near one of the screws).
Also as my door skin was "stuck" I thought I would remove the interior door panel to help give me access and see why the panel was stuck, DON'T bother you can't see/access anything from the inside of the door, all it resulted in was me having to buy some interior clips and a screw driver !
my interior mechanism flew apart during the process, so had to order one from VW only £27.99. should be finished tomorrow !
my Chinese OEM door mechanism, from ebay is fully working, vagcom errors have all been cleared and double tested, they have not returned central locking works a treat.
only other tip is as I think someone else posted to fit the blanking plug make sure you pull the handle as thought your opening the door this pulls the mechanism towards the door making the blanking plug connect when tightening the screw.  it took me ages to work that out !!
thanks again for sharing.
« Last Edit: March 18, 2016, 10:16:01 am by pjuster »
Offline Georrge
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,93533.msg937034.html#msg937034
« Reply #68 on: April 30, 2016, 04:53:37 pm »
I just got a new module off ebay, need to tackle this soon..
Instagram @george_kersh
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #69 on: April 30, 2016, 08:03:46 pm »
What mileages are they going at on your cars gents?.
Offline Berry
« Reply #70 on: May 02, 2016, 05:33:05 pm »
89k for mine
Shadow Blue MK5 GTI
Offline DANBOY66
  • -Given: 41
« Reply #71 on: May 02, 2016, 06:24:58 pm »
yeah i have 2 to do on the same car 4 door 90k
drivers door unlocks some times if it does not i use the key
drivers rear door wont even open  :scared:
any tips on opening a door that wont open  ? its clicking away when i press the key but nothing is happening
2 locks have been ordered from ebay
Dan..
Offline DaveE
« Reply #72 on: May 06, 2016, 11:03:02 pm »
Great guide, I will be using this soon to change 3 of my door lock modules!  :sad1:
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #73 on: May 07, 2016, 12:06:43 am »
89k for mine
Thanks for letting me know  :smiley:
Again thanks for letting me know. I also have a four door hatch at 74k so far so will not be looking forward to doing the replacement  :signLOL:
Offline DANBOY66
  • -Given: 41
« Reply #74 on: May 07, 2016, 12:40:10 am »
replaced both locks yesterday
rear door opened after pulling both hanles while pressing the button to unlock it
30 mins each lock to swap quite an easy job  :happy2:
Dan..
