Author Topic: Service due soon - have i missed anything?  (Read 1632 times)
Offline richtung
  • -Receive: 56
« on: August 24, 2012, 08:25:18 am »
Morning guys,
About to book the the ED30 in for a major service at an Indy, its 5 years old and on 48k miles.
For the full / major service, the main bits to be changed are:
Filters - air, pollen and oil. (fuel filter changed last year)
Oil change (Castrol Edge 5w 30)
Spark Plugs
Sun roof rail/guides lubricated
Top up fluids
full inspection
Extras:
Air con Service
Brake fluid change   (both last done 2 years ago)
Is there anything i have missed out that may need doing or should consider doing whilst in the garage?
Rich
Offline jimojameso
Re: Service due soon - have i missed anything?
« Reply #1 on: August 24, 2012, 02:11:29 pm »
Have you had the cambelt and water pump done yet? About that time.  :drinking:
Also is yours manual or dsg?
2010 Audi TT RS - Sepang Blue - 420BHP, 600NM
Offline richtung
  • -Receive: 56
« Reply #2 on: August 24, 2012, 02:33:31 pm »
had the cam belt and water pump done at 4 years and DSG oil and filter changed at 39k - by the book!  :innocent:
Rich
Offline jimojameso
« Reply #3 on: August 24, 2012, 03:27:15 pm »
Sounds like your all set then!  :happy2:
Offline Mk5 GTian
  • -Receive: 37
« Reply #4 on: August 24, 2012, 10:20:20 pm »
Cam Follower. 25 quid part, half hour to fit, and could cost four figures if it fails apparently. Got mine done at last service.
New plugs?
Offline richtung
  • -Receive: 56
« Reply #5 on: August 25, 2012, 09:16:45 am »
New plugs?
Plugs are being replaced as part of the service.
Good shout about the cam folower - forgot all about that. Will get that replaced!
cheers
Offline Tortaruga
  • -Given: 36
  • -Receive: 105
« Reply #6 on: August 25, 2012, 09:30:25 am »
Could possibly check PCV and diverter valve for leaks, unless you've done this yourself?
Also make sure they don't "wash" your car. :smiley:
'07 Red manual
Offline Tortaruga
  • -Given: 36
  • -Receive: 105
« Reply #7 on: August 25, 2012, 09:31:16 am »
Sorry just noticed you're going to an Indy so they won't wash it presumably.
'07 Red manual
Offline richtung
  • -Receive: 56
« Reply #8 on: August 25, 2012, 09:37:10 am »
Good shout on the PCV and diverter valve! Will ask him to check
He does acutally wash the cars - will ask him not to!
Rich
Offline Mk5 GTian
  • -Receive: 37
« Reply #9 on: August 25, 2012, 09:53:42 am »
I did the Rev D DV as well. I did what you're doing, got the whole lot done at the same time. All knowledge learnt and shared on this brilliant forum  :happy2:
Offline richtung
  • -Receive: 56
« Reply #10 on: August 25, 2012, 10:03:48 am »
Totally agree!!  :happy2:
Is this just a visual check?
sounds daft but is the PCV valve and Diverter valve their actual names or are they called something different on the VW parts system / ETKA?
Offline Tortaruga
  • -Given: 36
  • -Receive: 105
« Reply #11 on: August 25, 2012, 10:13:41 am »
DV is a remove & visual inspection. PCV - I think the same, where you can see if the internal flap is broken. Don't worry the Indy will know what to look for!
I think Etka calls the DV a "cut-off valve", but don't quote me on that. Not sure about PCV.
'07 Red manual
Offline tom.b
« Reply #12 on: August 25, 2012, 10:54:55 am »
I just had the same service 5 years old had cambelt and water pump kit, and cam follower  cost £700 all in but the cam follower was fine 28k 10k stage 1 but suppose its peice of mind.... Oh mine a mk2 Leon cupra though...lol
