Author Topic: VW just called. Snapped cylinder head bolt. : (  (Read 2206 times)
Offline ED30_jase
« on: August 24, 2012, 04:13:13 pm »
Yep while changing my head gasket they have snapped a bolt off in the head....
What are the implications??
I'm a bit pissed off as its been there a week now! and not going to be ready till Tuesday now,
Sad face indeed!
Saintsteve
Re: VW just called. Snapped cylinder head bolt. : (
« Reply #1 on: August 24, 2012, 04:23:59 pm »
Oh that's not good, depends where it's snapped, if it's snapped flush to the engine block then it's drill the bolt shaft and helicoil , not easy as they are toughened bolts.
if its sheared not flush then a stud extractor could still save the day. Either way, drilling with the head off the engine with lots of metal swarf is not good with an opened up engine :sad1:
not a job to be rushed
Or there is a process called Spark erode, but that would be engine out, fully stripped down and done that way.. But not sure that method is still used today..
« Last Edit: August 24, 2012, 04:25:38 pm by Saintsteve »
Offline ED30_jase
« Reply #2 on: August 24, 2012, 04:28:44 pm »
This is making me as snapped as the dam bolt!!
They said its sheered off : (
That's all they said but I'm hoping they do a good job of sorting it out! Can't believe all this after thinking it was a simple coolant leak!
Hopefully they won't get anything in the engine and they give it a good oil change and it comes back all sorted!
Offline ED30_jase
« Reply #3 on: August 24, 2012, 04:29:42 pm »
I would be happy if they did that and stripped it all down and cleaned it all out! : )
Offline E30Dom
  • -Given: 42
  • -Receive: 76
« Reply #4 on: August 24, 2012, 04:30:37 pm »
Are they use once stretch hea dbolts on these engines?
Diesel Daily Hack.
Offline ED30_jase
« Reply #5 on: August 24, 2012, 04:34:08 pm »
I'm not sure they said they've got all new bolts to put in?
Offline E30Dom
  • -Given: 42
  • -Receive: 76
« Reply #6 on: August 24, 2012, 04:36:50 pm »
Well some monkey has overtighten it then... I'd be onto VW UK just incase...
I am scepticle though bu knowing delaers they probably tried to use the old ones... either torqued used, or overtightened new.. it wouldn;t just snap.
Diesel Daily Hack.
Offline martziniuk
« Reply #7 on: August 24, 2012, 05:48:24 pm »
Probably snapped when it was being removed, nothing you could do about that really.
Offline higher1
« Reply #8 on: August 24, 2012, 07:51:09 pm »
I'm sure the work will be warranted for a while so I wouldn't worry to much
Ah-exclusive custom ultra low H&R Coilovers 110mm, ITG induction kit, 18" super RS's, USA rear bumper, USA front grille with smooth number plate surround,recaro bucket seats. now sold !
mk1 golf 1.8 20v turbo
