Author Topic: ***** The How To Guide Thread *****  (Read 200365 times)
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=9hec6ubpi98br74iq7dvess6u0&/topic,19740.0.html
« on: August 25, 2012, 05:21:55 pm »
********** Work in progress **************
LOCAL GUIDES IN RED
EXTERNAL GUIDES IN BLUE
ENGINE, GEARBOX AND SERVICING
Cam Belt Replacement 2.0TFSI
Cam Cover Removal And Replacement 2.0TFSI
Cam Chain and Tensioner DIY
DSG Basic Settings Tutorial
DV K04 Removal and Fitting
DV Relocation K03 to K04 Position
DV and PCV Diagnostic
EGR Valve / EGR Cooler Delete Mk5 TDI (BKD / BMN)
Engine Cover Modification for Aftermarket Air Intake
Removing Engine Cover
Fuel Pump Cam Follower
Fuel Pump Cam Follower - Video
Fuel Pump Removal and Fitting
Intake Valve Blow-By Cleaning
PCV Change
PCV Change (another link)
Rear Engine Mount Insert
S3 Intercooler Install
Spark Plug Change
Timing Belt Change
Wurth Engine Flush and Oil Change 2.0TFSI
How to change your inline thermostats (Long warmup problem)
EXHAUSTS
CHASSIS AND SUSPENSION
Changing/Replacing Rear Anti Roll Bar
WALK Fitting Instruction Video
How to cut front springs H&R supersport for more front rake
BRAKES
R32/S3 Front Brake Fitting
Brake bell refurbishment
NQSBBK Fitting
Rear brake upgrade
EXTERIOR
Boot Pop Modification (YouTube)
Doorlock Module Replacement
Front Grill Removal
Door Skin Removal
Fog Light Grills - DIY Open Grills
Headlight 'Joey" Mod
Magnetic Number Plate Fixing
OEM Rear View Camera Install
R32 Rear Bumper Install
Rear Badge Placement
Rear Valance Removal
Side mirror housing and side mirror lens removal
Wet sand headlights
INTERIOR
Ashtray/Ashtray Lid removal Mk5 Golf
'Alu Strip' Trim Removal
Bulb changing interior and exterior
Door Card Removal (YouTube)
How to fit an Armrest
Heated Seats Retrofit (using Kufatec Loom)
Manual Gear Knob Gator Removal/Fitting
Rear Bench Removal
How to fit underseat draws
3DR Sliding Seat Repair
Passat Switch Fitting
Removal of Boot trim and Removal of rear wiper motor
AUDIO, NAVIGATION AND PHONE
RNS510 How To Update The Firmware
RNS510 Adding Speed Camera Locations On The Map Display
How To Add AUX-In To An MDI Kit
How to retro fit a 6 CD changer, IPod, USB or MDI dock
How to replace/change a head unit
How to run speaker cable through door connector
LIGHTING
Door Warning Lights
High Level Brake Light Removal
OEM LED Lights - Skyline Modification
Puddle Light Retro Fit
Skyline tail light mod for Jetta
ELECTRICAL
Adding additional circuits to fuse board
Boost Gauge DEFI 52mm and OSIR Vent Pod
Cruise Control Fitting
Can Gateway Swap
CECM Swap
DSG Paddle Fix
Key Disassembly
OSIR Replacement DSG Paddle Shifters
Midline to Highline Clock Retrofit
Passat Interior Switches
Skoda 1Z0 035 729B Bluetooth Kit
« Last Edit: September 09, 2017, 10:06:59 pm by dazza »
Re: The How Guide Thread
« Reply #1 on: August 25, 2012, 09:34:07 pm »
If anyone has bookmarked good DIY guides on here post them up and ill add them to the list. Its taking me ages to sift through 70 pages!
Re: ***** The How Guide Thread *****
« Reply #2 on: October 09, 2012, 10:08:35 pm »
OK.. gonna start adding external links now and mark them as Blue to help differentiate.
Any guides you know of whack them here and ill add them.
Offline smokey
    • Club night in Bristol - Drama
« Reply #3 on: October 30, 2012, 02:13:48 pm »
Great to see one of my guides has been used here  :happy2:
2004 GT TDI 2.0 (140bhp) - Mods so far - GTI pedals, GTI Interior Metal Strips, GTI Metal Ashtray, Gear Knob with metal surround, TPMS (with switch), RNS-510, Skoda bluetooth kit, Armrest MDI, VCDS owner (Bristol)
« Reply #4 on: November 06, 2012, 01:59:40 pm »
Updated.
« Reply #5 on: November 23, 2012, 11:57:01 pm »
Ta.. will add them soon.
Offline marko
« Reply #6 on: December 31, 2012, 12:46:51 am »
awesome read....
 :happy2: :happy2:
Offline Nodz
  • -Given: 73
  • -Receive: 103
« Reply #7 on: January 12, 2013, 07:36:03 am »
Here's one Rich, fitting side skirts to a mk5
http://uk-mkivs.net/forums/t/53368.aspx
Offline torque777
Re: Re: ***** The How Guide Thread *****
« Reply #8 on: January 12, 2013, 08:47:29 am »
Wow some great guides there
sent using my own fingers
  • -Receive: 427
« Reply #9 on: February 04, 2013, 09:01:27 am »
« Reply #10 on: February 04, 2013, 09:06:09 am »
Thanks.. will add it later today.   :happy2:
« Reply #11 on: February 04, 2013, 09:39:55 am »
Great work Rich  :notworthy:
  • -Receive: 427
« Reply #12 on: February 07, 2013, 07:53:38 am »
A guide on "Fitting Side Skirts/Sill Extensions" just added by A1DAN2.0TDISPORT on here...
http://www.mk5golfgti.co.uk/forum/index.php/topic,61433.0.html
And also this one posted by VC a few years ago to get them off  "Removing Side Skirts/Sill Extensions".
http://www.mk5golfgti.co.uk/forum/index.php/topic,2209.0.html
« Last Edit: February 09, 2013, 10:26:50 pm by MC71 »
Offline Grande_GTi
  • -Given: 41
« Reply #13 on: February 15, 2013, 11:23:04 am »
Is there a DIY thread on how to replace the front wiper mech.??
Thanks in advance
instgram @ricky_grande
check out @lowlife_official
MK5 GTi OEM+
Offline doylebros
« Reply #14 on: February 15, 2013, 09:42:56 pm »
This will help you If you read past the first section but you may need to use a tool if the arms have never been off!
http://www.r32oc.com/topic/29242-canbus-gateway-location-removal/
Many thanks for the gateway.
« Last Edit: February 15, 2013, 09:45:54 pm by doylebros »
