Author Topic: Interesting facts!  (Read 8592 times)
Offline sub39h
  • -Given: 189
  • -Receive: 84
Re: Interesting facts!
« Reply #45 on: August 28, 2012, 03:32:55 pm »
the K03 is made by Borg Warner, which is a different company to IHI.
PLANS: Stage 2+
« Reply #46 on: August 28, 2012, 03:34:07 pm »
And the same company that make the K04.
Offline Tamiyoman
  • -Receive: 39
« Reply #47 on: August 28, 2012, 03:40:31 pm »
You can't change the point at which they spool however what that means is the K04 can last longer up the rev range where the K03 starts to run out of breath.
The Mk6 GTI is an IHI turbo not a K03.  :smiley:
Im pretty sure the mk6 gti is a k03... but i stand to be corrected.
The k03 definately spools quicker than the k04.
the Mk6 is definitely an IHI turbo
and i believe Stattler said he had some dyno runs that demonstrated that the K04 doesn't spool any slower than a K03
Can't say I notice slower spooling on the ED30 K04 than on my previous K03 GTI  :happy2:
Power to weight ratio (from Hurdy's post on Golfgtiforum):-
MKIV R32 power to weight is around 163bhp/ton
MKV R32 power to weight is around 166bhp/ton  :smiley:
MKV GTI power to weight is around 151bhp/ton
MKV ED30 power to weight is around 173bhp/ton  :P
All based on std manufacturer quoted figures, we all know that ED30's tend to make more than that and maybe the R32 does too?.
Wonder if when this thread will get locked too?
 :signLOL: :signLOL:
 :popcornsoda:
« Last Edit: August 28, 2012, 03:42:34 pm by Tamiyoman »
« Reply #48 on: August 28, 2012, 06:17:21 pm »
Yeah John makes the system work better. Which one is it ?
The HPA gen 4 one with remote control.
http://www.hpamotorsports.com/haldex.htm
« Reply #49 on: August 28, 2012, 06:22:42 pm »
That will make a huge difference to the car I would think and being able to adjust it when u want will be even better
R32UK
« Reply #50 on: August 28, 2012, 07:03:20 pm »
I figure this could well be down the different maps I have been running. Blufin v Revo.... which is a whole different can o worms  :signLOL:
The gti was definately more eager after a map.
Offline Tamiyoman
  • -Receive: 39
« Reply #51 on: August 28, 2012, 07:10:19 pm »
Maybe but as my K03 was only stage 1 and K04 stage 2 but they felt similar, if anything K04 may be 100-150rpm later but not noticeable tbh, what is noticeable is that the K04 keeps pulling up to 6500 and somewhat upto 7000rpm, whereas the K03 seemed to run out of steam at 5500rpm
R32UK
« Reply #52 on: August 29, 2012, 08:14:59 am »
without doubt the 04 pulls harder for longer. I think I read somewhere that the k04 turbo kicks in around 2400rpm. not sure about about k03 or the IHI on the mk6.
« Reply #53 on: August 29, 2012, 09:20:35 am »
Are they all done by the same driver ? If not then the stats are pointless  :evilgrin:
....Exactly!
Put a professional racing driver (or advanced trainer) in a car versus a higher performance car driven by someone less expert and guess who will achieve the faster lap time.
« Reply #54 on: August 29, 2012, 09:24:29 am »
....The K03 on my Stage 2 Revo Mk5 GTI kicks in at just under 2,000 rpm. For enthusiastic road driving but without getting into licence losing territory, that suits very well indeed.
R32UK
« Reply #55 on: August 29, 2012, 10:18:49 am »
That sounds about right Robin. There is no doubt that the k04 offers the larger gains overall but I have to be honest and say a remaped gti feels a little more 'sprightly' for everyday driving. Which is probably where my preference of the R32 comes in.... its much easier to get your speed up when you are looking for it, although that said I can confess that the R32 used to be driven much harder than the GTi has.
Offline Ree
« Reply #56 on: August 29, 2012, 11:29:19 am »
Would that have something to do with the V6 Roarrrrrrrrrr
« Reply #57 on: August 29, 2012, 11:36:15 am »
....Most definitely!!!!
When I test drove my GTI with a R32 back-to-back over a 40-mile lap with every kind of road in it, I found myself often in licence losing territory and also needed to find a petrol station much sooner than expected!
I've also driven a modified Mk4 R32 and a modified Mk5 R32 with Haldex Race setting and enjoyed both very much indeed. The V6 is a glorious sound and one which I can't get enough of. If the Mk5 .:R32 had come out earlier I would be in one now.... And of course it would be red!
