Author Topic: Rattles!  (Read 6300 times)
Offline daboy3000
  • MKV GT TDi
Re: Rattles!
« Reply #15 on: August 30, 2012, 05:14:21 pm »
Its not your balls banging around is it?  You know, the weights for the parcel shelf!!!
Offline ED30_jase
Re: Rattles!
« Reply #16 on: August 30, 2012, 11:54:55 pm »
Make sure the plastic cover under the armrest is firmly locked in position this rattles on mine sometime when someone has used it and not returned it!
Offline john87
  • -Receive: 53
Re: Rattles!
« Reply #17 on: August 31, 2012, 10:01:59 am »
I can confirm its not my balls banging  :wink: the noise still occurs when the shelf is out! However I've just noticed that the noise only starts to occur once the car is up to temp.. which makes me think it's something to do with the exhaust, even though the noise isn't a metallic 'clunk' . I'll be sure to have a good butchers under the car on tuesday when it's on the ramp. Thanks for your input, fellow mk5ers  :pomppomp:
Re: Rattles!
« Reply #18 on: August 31, 2012, 10:14:54 am »
Sounding more and more like the rattle is under the car. Also check the bolts on the exhaust tunnel cross ties, and obviously all bolts etc that you can see. Also that the exhaust system is hung clear of things it could rattle against.
Check this fuel line rattle too:  http://www.golfmkv.com/forums/showthread.php?t=18277
Do let us know what it was. Meanwhile:
Offline GS WAX
Re: Rattles!
« Reply #19 on: September 02, 2012, 08:24:42 am »
This will sound bizarre... have you checked the handbrake adjustment? i say this because i had a similar sounding noise on start up(minor clunking noise) or turn off and traveling over larger bumps as you describe,after  some routine brake maintenance at the dealers the noise vanished.
 Try applying the handbrake a couple of notches then open and close a door a few times to see if it makes the same noise.
old E30 beemers were the same,creaks when the handbrake is on as the suspension moves(usually when getting in the car)
Re: Rattles!
« Reply #20 on: September 02, 2012, 10:23:33 am »
Had a rattle from the front vents,ended up stripping the dash down to find it
Offline joseleeds
Re: Rattles!
« Reply #21 on: September 03, 2012, 10:53:08 pm »
i recently had a rattle/squeaking coming from the boot, turns out when i fitted rear lights my hesitation to over tighten the fastening bolts had resulted in it rattling itself off and rubbing on the boot lining!
rattles are insanely frustrating...i convince myself i need to replace all the parts on my car and all i have is a penny rattling around in the ashtray!!
Offline john87
  • -Receive: 53
Re: Rattles!
« Reply #22 on: September 07, 2012, 09:52:37 am »
The rattle seems to have left after I had the exhaust removed and replaced for pre-cat removal, so must have been something loose / hitting the underside of the car!
Thanks for your help all  :party:
Re: Rattles!
« Reply #23 on: September 07, 2012, 11:04:58 pm »
....Seems I guessed correctly: (:smug: smilie)
Offline john87
  • -Receive: 53
Re: Rattles!
« Reply #24 on: September 10, 2012, 08:42:56 pm »
 :congrats: god knows what part of it was rattling! Think it was the mechanical equivalent of 'turn it off and on again'  :wink:
Re: Rattles!
« Reply #25 on: September 10, 2012, 09:11:39 pm »
....As in Ch4 'The IT Crowd'  :laugh:
