Author Topic: Wolfsburg number plate Surrounds  (Read 3740 times)
Offline riz
« on: June 07, 2009, 12:27:17 pm »
I have fitted the rear, what is the best way to fit the front?
It doesnt seem to curve around properly!!!
Do i need to to take the big number plate holder off?
Offline mortygttdi
  • -Receive: 146
Re: Wolfsburg number plate Surrounds
« Reply #1 on: June 07, 2009, 01:09:26 pm »
Never seem to look good on the front, but yes you would need to take the plate plynth off to mount your plate holder,  Personally I put the rear one on and that was enough said.  :happy2:
Darren
Offline riz
« Reply #2 on: June 07, 2009, 01:35:41 pm »
oh ok sorted, how do i take the front bit off?
« Reply #3 on: June 07, 2009, 03:09:14 pm »
You need to take your front mask off which is easy, 4 screws, then the plinth is held on with little pins just tap them through with a hammer and a thin screw driver, it will become clear once the mask is off.  :smiley:
Offline big al
« Reply #4 on: June 07, 2009, 09:25:34 pm »
Im not too keen on them on the MK5,
My old MK3 had one, and it seemed to drop the plate quite often, lost one, and realised it had fallen off about 3 times.
Getting some pressed plates for the 5 instead.
Offline pazz
« Reply #5 on: June 08, 2009, 10:29:20 pm »
Where did you get the surrounds from?
« Reply #6 on: June 08, 2009, 10:43:49 pm »
There is literally  hundreds of sellers on eBay supplying any surround you can think of.  :happy2:
Offline riz
« Reply #7 on: August 06, 2009, 03:54:21 pm »
If i do this and put the wolfsburg surrounds on , will it look ok or still a little bent?
Offline Deako
  • -Given: 38
  • -Receive: 44
  • Eat, Sleep....VAG
« Reply #8 on: August 06, 2009, 04:23:41 pm »
I just fitted the rear surround for my legal pressed plates and bent the front plate slightly to fit. Used 3 number plate pads on it.
#1493
