Author Topic: new guy ! mk5 golf with porsche wheels and adpators offset query  (Read 3799 times)
Offline bedford8256
im new here so be gentle on me :)
just got a mk5 golf gt tdi and the wheels are terrible
seen some nice porsche wheels
rears are 18x10 et65
fronts are 18x.5 et50
i have found some adaptors to fit at 15mm wide  (5x112 to 5x130)
will these fit ok
thanks guys
Offline big al
Re: new guy ! mk5 golf with porsche wheels and adpators offset query
« Reply #1 on: August 30, 2012, 03:12:14 pm »
Think the rear will be too big unless you put a fair bit of camber in or want to do some major arch work.
I have 9x18 on the rear and they had to have 3 degrees camber put on to help tuck them.
And the fronts the most you can get away with is around 8.5 as the inside of the wheel can catch if any wider, or the outside on the arch.
Offline bedford8256
« Reply #2 on: August 30, 2012, 03:17:18 pm »
cheers mate
« Reply #3 on: August 30, 2012, 07:01:03 pm »
Welcome to the forum from another sooty owner
Offline JoeDarKa
  • -Given: 57
  • -Receive: 73
« Reply #4 on: August 30, 2012, 07:08:13 pm »
Iv just put 18x8s on the front and 18x9s on the rears. Will get some pics up later. And welcome!
Offline higher1
« Reply #5 on: August 30, 2012, 07:58:50 pm »
Are you on coilovers ? And what width is the front wheels there's a typo in your post ?
Ah-exclusive custom ultra low H&R Coilovers 110mm, ITG induction kit, 18" super RS's, USA rear bumper, USA front grille with smooth number plate surround,recaro bucket seats. now sold !
mk1 golf 1.8 20v turbo
Offline MR02LOW
    • Ironkilla Gym Apparel
« Reply #6 on: August 30, 2012, 09:08:38 pm »
Hi mate, like al has said, the rears will be no good running a 15mm spacer, I have 9.5 Porsche rims on the rear at the moment running a 20mm spacer which has taken the offset down to 37 and they still stick out from the body on max camber, you'll need the rear arches pulled for sure to get anything remotely lik a decent fit and if you not running coils or air it will look very odd.
Th fronts will be fine.
Tbh mate I would steer clear of the rims all together unless you can get some smaller rears.
Just my 2p worth buddy
Offline higher1
« Reply #7 on: August 30, 2012, 09:30:45 pm »
The rear wheels wont clear your rear shocks running 15 mm spacers Use this site to calculate http://www.1010tires.com/WheelOffsetCalculator.asp
