Author Topic: MDI Armrest install ?  (Read 5613 times)
Offline gobbleplease
  • -Given: 64
  • -Receive: 48
« on: August 31, 2012, 09:26:20 am »
Hi im looking to do a mdi armrest install to pair up with an RNS 510, ive already got the ipod armrest dock just a couple of questions
1) will i need coding ( or is it possible to code using polar fis + advanced )
2) Do you need a special loom to run to the arm rest eg kauftek or is there an oem loom
3) i take it this will work with i phone
4) has anyone got links to the install or partnumbers
5) is there any known converters to convert the ipod armrest dock in to iphone compatability
I realise that this will not be the same as highline
Ta
MK7 GTI - ARRIVING DECEMBER
Offline StephenED30
  • -Receive: 53
  • Edition 40 No 135
Re: MDI Armrest install ?
« Reply #1 on: August 31, 2012, 04:47:27 pm »
Yes
Yes, Look here.
 http://www.ebay.co.uk/itm/MDI-Kabelsatz-VW-Multimediabuchse-MEDIA-IN-RNS510-/170586485658?pt=Kabel_Stecker&hash=item27b7bf339a
Yes, as an iPOD not as a phone kit if its the MDI kit you have.
http://translate.google.co.uk/translate?hl=en&sl=da&u=http://vwfanatic.dk/Tips/G5Armlaen.html&sa=X&oi=translate&resnum=1&ct=result&prev=/search%3Fq%3D1K0%2B863%2B323A%2B71N%26hl%3Den%26rlz%3D1G1GGLQ_ENUK276%26sa%3DG%26pwst%3D1
have you got the iPOD dock or the MDI dock, there is a difference.
  • -Given: 64
  • -Receive: 48
« Reply #2 on: August 31, 2012, 06:51:54 pm »
Cheers ive got an ipod dock, this is not compatable with .  if i can buy a convertor to enable play and charge through the dock rather than splashing out on the mdi ill just do that, otherwise ill be removing my ipod dock in favour of the MDI
Any idea of a convertor then mate ?
Offline StephenED30
  • -Receive: 53
  • Edition 40 No 135
  • -Given: 64
  • -Receive: 48
« Reply #4 on: August 31, 2012, 08:52:46 pm »
Ah Ha ! Thats what i was looking for
Ta
Offline marko
« Reply #5 on: October 01, 2012, 07:43:09 pm »
whats the difference between ipod dock and the mdi dock??? :laugh: :laugh:
Offline bakili
« Reply #6 on: October 01, 2012, 08:15:25 pm »
MDI so much better
Ability play music from USB, i find sound quality is better as well.
Cant comment on Ipod/Iphones as do not have one.
Installation very simple kinder.
Did not need any coding, just plug and play.
Worse part was running loom to arm rest without removing it.
« Last Edit: October 01, 2012, 08:18:32 pm by bakili »
Offline brookesb32
  • -Given: 59
  • -Receive: 75
« Reply #7 on: October 01, 2012, 09:28:33 pm »
MDI so much better
Works really well from both an iPhone and iPod as my friend tried both when we installed his. The mdi also fully shows up on the rns units and rcd510 (touch screen versions basically) so you can see full track and album details. It also charges iPhones.
You only need to remove the plastic top And rear of the armrest, the wiring you can wiggle down the inside of the centre console  :happy2:
Offline marko
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #9 on: October 02, 2012, 12:02:56 am »
Hi
You also need the loom, which i have
or you can buy the full kit from me too
Cluster and Key coding
Location Great Yarmouth
Offline eddy_30
« Reply #10 on: October 03, 2012, 01:15:35 pm »
Hi Eddie-NL,
have you got retro fit MDI kits?
what's required to change out an existing 6 disc change and replace with an mdi setup in the armrest?
cheers
'08 Edition 30, DSG, Revo Stg 2+, DSG Stage 2 map, Milltek TBE,  Autotech HPFP internals, Forge DV, ITG CAI, front mounted machine guns, Porsche NQSBBK, SuperPro Antilift, H&R Rear ARB, retro fit armrest mdi, boot pop, Forge Twintercooler (cheeky little red hoses)..
VCDS-HEX+CAN
up next.. Wavetrak LSD and a front ARB
