Author Topic: Drivers window opening when trying to close  (Read 1135 times)
Offline Timi8888
« on: August 31, 2012, 10:30:16 am »
When the window is closed, I can open it to wherever I want it to stop. When it comes to closing it, the window will open further till it is nearly fully open. Then if I try again then it will shut. This happens everytime that I do this. Not a big problem but just a bit annoying. Anyone else have this problem?
Also there is a constant rattle in the drivers door, whether it be driving slow or driving quickly.
Can anyone help?
Sig to big.
MPS
Re: Drivers window opening when trying to close
« Reply #1 on: August 31, 2012, 11:28:09 am »
I've got 2 problems both exactly the same as yours.
I think the constant rattle is loose window regulator clips and the window going down when you want it to go up is the regulator motor is faulty.
