Author Topic: Cooling fan problem  (Read 2850 times)
Offline Timi8888
Cooling fan problem
« on: August 31, 2012, 02:11:18 pm »
Even after switch off, the fan on my car just keeps on going on off on off etc. The only way to stop it, is to unplug it, or wait till the engine cools down fully. It has turnt my engine management light on, and when plugged in to the diagnostics machine, it shows cooling fan 1 is faulty. Any help on this?
Sig to big.
Offline gigolo456
Re: Cooling fan problem
« Reply #1 on: August 31, 2012, 02:34:21 pm »
Perhaps an obvious question but are you sure both fans are actually working??
Offline Tortaruga
  • -Given: 36
  • -Receive: 105
« Reply #2 on: August 31, 2012, 02:35:52 pm »
Sounds like one of the fans is broken. have a look at this thread:
http://www.mk5golfgti.co.uk/forum/index.php?topic=29147.0
'07 Red manual
Offline Timi8888
« Reply #3 on: August 31, 2012, 02:36:52 pm »
Only the big fan at the front goes on and off continuously...
Sig to big.
Offline gigolo456
« Reply #4 on: August 31, 2012, 02:39:54 pm »
Well IF your smaller fan isn't working, your larger fan will be working overtime to compensate, happened to me recently...
Offline Timi8888
« Reply #5 on: August 31, 2012, 02:45:56 pm »
Best thing to do is to take it to a VW specialist garage? So that I don't replace both fans when it is only one which doesn't work?
Sig to big.
Offline gigolo456
« Reply #6 on: August 31, 2012, 02:52:26 pm »
well i would assume it's your smaller one that doesn't work. Switch your air-con on, pop the bonnet open, look down, if your bigger fan is the only one that's working, then yes, your smaller one is broken. It's not a huge problem if that's the case to be honest, i got mine fixed just for peace of mind, but it was only at that point i discovered that my radiator was leaking, so had that replaced as well...  :sad1:
Offline Timi8888
« Reply #7 on: August 31, 2012, 03:04:46 pm »
Where is the smaller one positioned? Should I be able to see it moving by just looking down with the bonnet open?
Sig to big.
Offline Gazza747
« Reply #8 on: August 31, 2012, 03:12:10 pm »
It is at the front of the engine bay and yes you can see it easily from the top. When my ac wasn't working I could see the fan wasn't spinning.
2013 Golf mk7 1.4 tsi SE DSG
2011 Golf mk6 2.0 tdi Match manual (sold)
2007 Golf mk5 GTi manual (sold)
Offline gigolo456
« Reply #9 on: August 31, 2012, 03:29:39 pm »
That may not b the problem of course, mite b a sensor, r summit like that. Best take to a recommended independent specialist!
Offline Timi8888
« Reply #10 on: August 31, 2012, 03:31:09 pm »
Yeah I have had the temperature coolant sensor replaced today. Cleared that fault from diagnostics, but the engine management light came back on with just the PO480 Engine Cooling Fan 1 left to fix.
Sig to big.
