Author Topic: Annoying brake light problem  (Read 1148 times)
Offline vag12
« on: August 31, 2012, 09:59:19 pm »
As above basically when i turn the car off and click the lock button with remote the car will lock and all lights will go off, usually around 7am in the morning which is like 9 hours later the brake lights seem to turn on somehow?
And the only way to turn it off is to open the car and press brake pedal once and release and then lock car again, Just unlocking and locking the car wont work.
Has anyone got any idea why this is or what is causing the problem?
Offline vag12
Re: Annoying brake light problem
« Reply #1 on: September 01, 2012, 12:24:54 pm »
Anyone?
Offline apples12
« Reply #2 on: September 01, 2012, 06:09:59 pm »
Sounds like a problem with brake pedal switch, I'm certain there's a way to adjust it
MK6 GT TDI  - CW - LUX pack
GONE
Offline vag12
« Reply #3 on: September 01, 2012, 07:24:35 pm »
Not sure what needs adjusting? It just comes on out of no where
vw55raz
« Reply #4 on: September 01, 2012, 07:33:48 pm »
get a diagnostics done with vcds. Brake pressure sensor is common fault on mk5 golfs. sometimes it could bean easy fix or end up replacing the whole abs pump which is a lot. but there are companies out there who rebuild abs pumps with a warranty.
Offline vag12
« Reply #5 on: September 01, 2012, 08:37:04 pm »
Thanks, Under which section do i search for brake presure sensor if you know?
