Author Topic: New seats  (Read 3450 times)
Offline JoeDarKa
  • -Given: 57
  • -Receive: 73
Re: New seats
« Reply #15 on: October 25, 2012, 08:06:23 pm »
For future reference if anyone needs a new plugs after changing seats:
8E0 972 710 = Under seat plug
000 979 023 = 0.5mm wire with connector
000 979 135 = 1.0mm wire with connector
000 979 227 = 2.5mm wire with connector
000 979 306 = 4.0mm wire with connector
The "thin" wires under the seat are the 0.5mm / 1.0mm.
The "thick" wires under the seat are the 2.5mm.
Il update more with coding side of things when i get mine fitted
Offline JoeDarKa
  • -Given: 57
  • -Receive: 73
Re: New seats
« Reply #16 on: November 05, 2012, 08:12:59 pm »
Right, managed to fit my seats... In the dark!
Couple of tips, if making the airbag resistors, the metal bits need to be really pulled through so a tiny pair of needle nose plyers are useful. Otherwise they wont click in place.
I believe the red and black wire is actually part of the electric lumbar system.
To turn the seatbelt warning you need to go into instruments - 17 then recode - 7. From the 4th digit, you minus 2. Mine was 5 but was changed to 3
