Author Topic: Airbag Light Issue.  (Read 1674 times)
Offline Munzz
Airbag Light Issue.
« on: September 01, 2012, 09:54:18 pm »
Hi All
I went over a speed bump last week at well under 1MPH as the bump always catches my car somehow and 2 seconds later my airbag light illuminated and the dash displayed "Airbag Fault".
I had a friend perform a scan and the error was:
01217 - Side Airbag Igniter; Driver Side (N199)              001 - Upper Limit Exceeded - Intermittent
I've checked both seats and all wiring seems to be intact and plugged in but the light just wont turn off.
Is this a common issue, any easy solutions or is it a dealer jobbie?
Any assistance is appreciated.
Thanks.
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
Re: Airbag Light Issue.
« Reply #1 on: September 01, 2012, 09:58:01 pm »
if your car is 2004 - late 2006
and probably a 3dr then it is a common issue
cut the plugs off an solder the wires
Cluster and Key coding
Location Great Yarmouth
Offline Carla77
« Reply #2 on: September 01, 2012, 11:57:18 pm »
I have an 04 5dr and this used to happen all the time (cattle grids are the worst offenders!!) The wiring loom is too short and any jolt will set the light off. As stated before, cut the plugs and solder the wires.
Offline Munzz
« Reply #3 on: September 02, 2012, 05:26:07 pm »
Thanks for the responses guys, It is a 3dr and 2006 which seems to fit the criteria.
Is it an easy job to do, anyone had to do it before?
Offline skard
  • -Receive: 245
« Reply #4 on: September 02, 2012, 05:30:16 pm »
See http://forums.vwvortex.com/showthread.php?2815467
Fixed my airbag igniter fault, easy to do but you'll need the airbag fault cleared afterwards.
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #5 on: September 02, 2012, 05:33:52 pm »
it is fairly easy, but you need a soldering iron, heat shrink and tape
Offline Munzz
« Reply #6 on: September 11, 2012, 08:46:38 pm »
Thanks for the responses guys, honestly dont have the ball's to do this myself so will take it to VW.
Any idea of cost?  :sad:
Offline Nodz
  • -Given: 73
  • -Receive: 103
« Reply #7 on: September 11, 2012, 08:48:49 pm »
Where abouts are you located? There might be someone near to you who can do it as VW will probably charge a small fortune
Offline Munzz
« Reply #8 on: September 11, 2012, 09:33:55 pm »
I'm based in Northampton, I'd be willing to pay someone local if they know what they're doing!
Offline Munzz
« Reply #9 on: September 19, 2012, 08:42:55 pm »
Anybody interested in assisting a man in need?
I've looked in to this a little more and may give it a go myself but I've heard horror stories occur when an airbag is involved!  :fighting:
Offline Degudodger
  • -Given: 53
  • -Receive: 86
    • Flickr
« Reply #10 on: September 19, 2012, 10:00:51 pm »
You have nothing to worry about as long as you disconnect the battery and ensure you don't connect the wires the wrong way round.  :smiley:
Offline Munzz
« Reply #11 on: September 20, 2012, 05:32:28 pm »
Thanks mate, I may well give it a go this weekend!
Wish me luck  :star:
