Author Topic: Car judders when on idle  (Read 11652 times)
Offline Timi8888
« on: September 02, 2012, 01:43:35 am »
I have been having trouble when my engine is on and I come to a stop. It is worst when the engine has fully warmed. The car is shaking every now and then. What could this be?
Sig to big.
Offline Ree
Re: Car judders when on idle
« Reply #1 on: September 02, 2012, 02:11:50 am »
Are they very low thumps !
I have this sometimes on idle and have been advised its normal, it's the car burning unused fuel !
I have experience this is on two other cars but they were both R32 like mine so am not 100% if this is an R32 behaviour or happens on other MK5.
Offline Timi8888
« Reply #2 on: September 02, 2012, 02:15:03 am »
Mine isn't a R32, but at same time it judders quite a bit, like the engine is misfiring, but the revs stays the same?!
Sig to big.
Offline SteveS
« Reply #3 on: September 02, 2012, 08:40:33 pm »
Possibly PCV, lots of people mention it.
Worth taking your off and making sure the seal is good (check for oil etc)
replaced mine today, not driven yet, but im pretty sure there was air leakage (splattered bits of oil around tthe  bottom)
SOLD!! :(
VW GTI Edition 30 No. 0551
Revo Stage2+ (LT) | Evoms Intake, K&N Filter | VWR LSD | Milltek R32 TBE | VWR Engine Mounts | VWR Big Front & S3 Rear Brakes | VWR Springs |  VWR Shortshift | SuperPro Bushes |  Recaro Seats
Offline Timi8888
« Reply #4 on: September 03, 2012, 09:30:49 am »
What's this PCV you are talking about Steve? And is it easy to do yourself?
Sig to big.
Offline SteveS
« Reply #5 on: September 03, 2012, 12:01:40 pm »
One which goes on the top on the engine block..
I replaced mine, seems a bit better but i don't think it was screwed on tight....
The one i removed was actually fine. Now i have removed it, i think it was already replaced at some stage..
SOLD!! :(
Offline scopes
  • -Given: 131
  • -Receive: 115
  • Wolfsburg Edition
    • My GTI
« Reply #6 on: September 16, 2012, 12:05:59 pm »
Is there an easy way to change the larger breather pipe that fits in from the pcv to the lower part of the engine?  :happy2:
Silver is the way !
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
« Reply #7 on: September 16, 2012, 01:27:37 pm »
Noticed mine doing this today. I replaced my PCV earlier in the year.
Could be normal  :confused:
Offline john87
  • -Receive: 53
« Reply #8 on: September 16, 2012, 08:53:05 pm »
could be a coil pack on its way out or spark plug that needs replaced?
Offline Timi8888
« Reply #9 on: September 16, 2012, 10:12:00 pm »
I'm not too sure how to check th PCV?
Sig to big.
Offline Beddie
  • -Receive: 76
« Reply #10 on: September 16, 2012, 10:15:30 pm »
Pull the dipstick out or remove the oil cap when the engine is running smoothly, it should start to run rough/lumpy if the PCV is failing  :happy2:
If you notice no change it may be because your PCV has already failed, either way for the cost (£27) and time (10mins) involved i'd replace it anyway to rule it out  :smiley:
Carbon Grey Edition 35 - Here
Offline john87
  • -Receive: 53
« Reply #11 on: September 17, 2012, 09:52:06 am »
I'm afraid I'd have to disagree with you there - if the car runs lumpy when the dipstick is pulled out, this does not constitute that the PCV is failing...however if it does not run any lumpier when the dipstick is removed, chances are there is a problem with the PCV  :happy2:
Offline Timi8888
« Reply #12 on: September 17, 2012, 10:31:00 am »
Can anyone tell me what the PCV looks like lol. On a 1.6 fsi?
Sig to big.
Offline callis
« Reply #13 on: September 17, 2012, 12:42:53 pm »
what year and engine model?
05 GTI 5 Door, sunroof, met paint, 18" monza, Leather Anthacite, front centre armrest, xenon headlights, Lux pack 2, Sensors, Winter Pack.
Offline Timi8888
« Reply #14 on: September 17, 2012, 12:44:15 pm »
It is a 04 reg 1.6 fsi
Sig to big.
