After having a new turbo fitted and giving the courtesy car back I have noticed the biting point on the clutch is very low.
I have read that the clutch does not have a cable so is hydraulic so the biting point should self adjust.
Could it just need the clutch fluid replaced or could it be the clutch and/or dmf?
Is there a way I can test/check for faults or does this sound normal?
