you would have had it earlier.
is that polar FIS still fitted?
Ed when I installed the polar with the new gateway, the gateway came up with the error "No response from controller" when scanned with vcds.
I had a word with mun100 who programs the software for polar and he sent me an unreleased beta version firmware to see if it cured my problem. The polar screen appeared in the mfd but a vcds scan still showed the "No response from controller" error.
I was told that I shouldn't have a battery drain problem with the polar installed even with the old gateway. I elected to use the old gateway with the polar on the strength of this but with the knowledge that the next firmware update for the polar in a couple of weeks time will address my problem with the newer gateway.
In the meantime I want to be reassured that if my battery isn't flat in the morning then the polar is doing its job.
