Author Topic: Spark Plugs  (Read 9812 times)
Offline Jaywoo-GTI
  • -Given: 38
Spark Plugs
« on: June 08, 2009, 02:27:09 pm »
Looking to upgrade my plugs to iridium items, Either NGK or Denso as i have used them in the past with impressive results.
Does anyone have any other good upgrade/recommended plugs or even the part numbers for the plugs i should be looking for?
Also what manufacturer and part number are standard VW items so i can X-Ref them?
Jay
Offline iainalpine
Re: Spark Plugs
« Reply #1 on: June 08, 2009, 02:56:03 pm »
Have a look at these mate. There have been some real good things being posted about them. Also have a look on the site with the demo on how the flame front moves http://www.pulstar.com/ignitionvelocity.htm There is some real interesting stuff here. With these in place you could advance the timing quite a bit which would increase BHP and Torq.
Iain
2006 MKV GTI, DSG, Stg2 Revo map, VWR front splitter, KWv3's, Eibach rollbars, Walk kit, Carbonio induction kit, Full Milltek exhaust system, Forge FMIC
Re: Spark Plugs
« Reply #2 on: June 08, 2009, 04:26:35 pm »
Are you stock or remapped?
If stock, stick with the oem plugs.
Offline Jaywoo-GTI
  • -Given: 38
Re: Spark Plugs
« Reply #3 on: June 08, 2009, 04:55:52 pm »
What are OEM plugs?
Its stock at the min but is goin in within the next month for a remap so looking at gettin everthing i can first.
Offline DanGB
  • Different
Re: Spark Plugs
« Reply #4 on: June 08, 2009, 05:20:55 pm »
The good upgrade plugs are NGK Iridium BKR7EIX. They are one heat range colder. The BKR6EIX are a direct replacemnt. These are highly recommened by alot of people. I use them myself on my stage 3 car.
Seat Leon Mk2 TFSI sport 4WD sleeper - Breaking
Buld thread: http://www.mk5golfgti.co.uk/forum/index.php/topic,45377.0.html
Offline WhiteGTI
  • F-A-S-T
Re: Spark Plugs
« Reply #5 on: June 08, 2009, 10:57:25 pm »
Iain
To those in the know: Would these be beneficial for my Stage 2 GTI ???
2006 E46 BMW M3 - 343hp
Re: Spark Plugs
« Reply #6 on: June 08, 2009, 11:10:53 pm »
JKM, VWR, and others have all advised me that I don't need to change plug type on my Stage2 GTI. I change plugs every 20k miles but to the same oem ones.
Offline Poppa Dom
Re: Spark Plugs
« Reply #7 on: June 08, 2009, 11:11:18 pm »
Iain
Quite an interesting read here Chris - http://chris.pirillo.com/spark-plugs-vs-pulse-plugs/
Re: Spark Plugs
« Reply #8 on: June 08, 2009, 11:15:19 pm »
Iain
....But you best know exactly what you are doing if you are going to do things like big timing advances. You may increase power but what else will be going on? Would you then, for example, need an aftermarket fuel pump?
Re: Spark Plugs
« Reply #9 on: June 08, 2009, 11:19:32 pm »
....I found it interesting but not convincing.
Offline Poppa Dom
Re: Spark Plugs
« Reply #10 on: June 08, 2009, 11:24:31 pm »
Yes, I am definitely not convinced on this one. At the end of the day detonation is detonation, irrespective of the strength of the spark.
Offline neg
  • gone old skool
Re: Spark Plugs
« Reply #11 on: June 09, 2009, 01:07:07 am »
OEM (Stock) plugs are fine on stock and remapped cars - no real 'need' to upgrade them - just swap them more often than normal if remapped.
As for altering the timing, this maybe so but you need to do some data logging to make sure your not making the ECU pull the timing back too much - all about the CF values and keeping them low.
Offline Jaywoo-GTI
  • -Given: 38
Re: Spark Plugs
« Reply #12 on: June 09, 2009, 08:57:55 am »
I have never really understood heat ranges, What does a colder plug mean?
Re: Spark Plugs
« Reply #13 on: June 09, 2009, 09:55:41 am »
Have a read.   :smiley:
http://www.ngk.de/Spark_plugs.649.0.html
Re: Spark Plugs
« Reply #14 on: June 09, 2009, 11:10:42 am »
I've forgotten, but aren't the oem plugs NGK?
