Author Topic: 1.9tdi losing coolant and got very hot help please  (Read 1342 times)
Offline Neiltdi
  • Full Hex+CAN
« on: September 07, 2012, 05:34:26 pm »
Hi guys on ny way home from work today cruising down the motorway at 70 looked down at tenp gauge and it was just below 130! Pulled over and there was no coolant in my header tank so filled it up with 1.5 litres of water i had in the boot and let it cool down drove the rest of the way home (about 5 miles) and it sat at 90 the whole time got about a mile away from home and the temp light came on popped the bonnet and had no coolant again , anyone got any ideas?
Neil
Full Hex+CAN in Hampshire.
Offline Degudodger
  • -Given: 53
  • -Receive: 86
    • Flickr
Re: 1.9tdi losing coolant and got very hot help please
« Reply #1 on: September 08, 2012, 03:54:25 pm »
Hi Neil,
Has the cambelt been changed recently or any other service work.
- Check the oil, is there any white gunk on the dip stick or the filler cap or any oil in coolant header tank.
- Fill the system with coolant, let it sit for a couple of hours then start following the coolant pipes inspecting all the joints for signs of moisture.
- Take the bottom engine cover off and with the engine running check for any leaks with a torch.
Offline Neiltdi
  • Full Hex+CAN
« Reply #2 on: September 08, 2012, 06:00:03 pm »
Hi dodger
I had a look today and couldnt find any leaks i also did a cambelt and water pump on her As i thought it may be the pump but it was in great condition.
There isnt any white gunk ( also did a sniff test) and that came up negative.
Offline Degudodger
  • -Given: 53
  • -Receive: 86
    • Flickr
« Reply #3 on: September 08, 2012, 06:28:35 pm »
Good news about the sniff test so you can for the moment rule out the Head Gasket. Did you check the radiator including the edges?
« Reply #4 on: September 09, 2012, 03:04:06 pm »
Could be totally wrong but depending on your year model what you are seeing could be down to a porous or cracked head.
Offline Degudodger
  • -Given: 53
  • -Receive: 86
    • Flickr
« Reply #5 on: September 09, 2012, 05:09:48 pm »
Don't think the BXE engine is effected by the Porous head issue like early 140Bhp 2.0 TDI heads.
Offline Neiltdi
  • Full Hex+CAN
« Reply #6 on: September 12, 2012, 05:58:03 pm »
Little update changed the cambelt and waterpump at the weekend picked my friend up from the airport today 150 mile round trip and didnt lose any coolant , about 10 minutes ago i got it pressure tested and found no leaks and the gauge disnt move at all?
When i removed the waterpump i found no signs of a leak or a faulty waterpump
Offline Degudodger
  • -Given: 53
  • -Receive: 86
    • Flickr
« Reply #7 on: September 17, 2012, 09:17:44 pm »
Could have been a dodgy seal. Did you use OEM parts or after market?
Offline Neiltdi
  • Full Hex+CAN
« Reply #8 on: September 17, 2012, 09:30:25 pm »
I only use o.e Parts on my golf , its still okay done a fair few miles hopefully it has cured the issue
