Author Topic: Broken engine, where would you go from here  (Read 4800 times)
Offline AndyS
Re: Broken engine, where would you go from here
« Reply #15 on: September 09, 2012, 05:33:54 pm »
Just had an engine replaced by Steve at Stattlers, and what a great job he did. I would Highly recommended him...........
Offline af1
« Reply #16 on: November 03, 2012, 05:32:16 pm »
Well, I stripped all the side of the engine down and replaced the chain, refitted the balance chart and put a new Cambelt on it...
Started up straight away.. But sounds a bit tappy... I haven't had the car running since June, I can't remember if the engine tapped this loudly before?
I'm pretty chuffed I did it all for myself.. The ticking is coming from around the fuel pump but there is a bit of a thud on the engine too...
It's only an iPhone vid.. Do you think it sounds ok? It doesn't seem particularly smokey, bearing in mind the maf is disconnected and the intake pipe work
Offline martziniuk
« Reply #17 on: November 03, 2012, 07:17:41 pm »
The link doesn't work
Offline af1
« Reply #18 on: November 03, 2012, 07:20:59 pm »
http://m.youtube.com/watch?feature=plcp&v=ksLCGgeZZTg
I have listened to a few on youtube and they all sound similar tbh
Offline Horatio
  • -Receive: 39
« Reply #19 on: November 04, 2012, 06:41:09 am »
When I had my eddy30, it sounded exactly like this. Even after Cambelt/WP change it still sounded tappy but softer. I think it's pretty much standard.
Offline AndyS
« Reply #20 on: November 04, 2012, 10:49:14 am »
When I first got my GTI I had VW look at the engine due to the tapping noise, they said it was normal.
A month or two later the oil pump gave way and tock the engine out. My new engine does not make the same amount of noise as the old one !
Offline af1
« Reply #21 on: November 04, 2012, 03:32:15 pm »
That's exactly what happened to this enginr
