Author Topic: Fault code diagnostic please help out guys!  (Read 5932 times)
Offline vag12
« on: September 08, 2012, 07:04:34 pm »
Just had a full vagcom scan on my car to check for issues and came back with loads of them, Not really sure which ones point to what direction, Will be really greatfull if someone points me to the right direction.
I can also say that i knew beforehand that the AC is not working properly and a brake light issue where the brake light seems to come on about 2 hours after the car is locked and constantly stays on,
many thanks in advance  :drinking:
VCDS Version: Release 11.11.3 (x64)
Data version: 20120401
Saturday,08,September,2012,18:45:17:18174
Chassis Type: 1K0
Scan: 01 02 03 08 09 15 16 17 19 25 37 42 44 46 47 52 55 56 62 65
          72 76 77
VIN: WVWZZZ1KZ5W229425   Mileage: 136170km/84612miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: Cannot be reached 1100
52-Door Elect, Pass. -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
65-Tire Pressure -- Status: Cannot be reached 1100
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: OK 0000
77-Telephone -- Status: Not registered 0011
Address 01: Engine        Labels: 06F-907-115-AXX.lbl
   Part No SW: 1K0 907 115 L    HW: 1K0 907 115 A
   Component: 2.0l R4/4V TFSI     0010
   Revision: --H01---    Serial number: VWZ7Z0E1865585
   Coding: 040300031C070160
   Shop #: WSC 00191 264 15243
   VCID: 2F670FF8BE066D1
No fault code found.
Readiness: 0110 0100
Address 02: Auto Trans        Labels: 02E-300-0xx.lbl
   Part No SW: 02E 300 042 M    HW: 02E 927 770 AD
   Component: GSG DSG         041 0824
   Revision: 04004010    Serial number: 00000503080506
   Coding: 0000020
   Shop #: WSC 00000 785 00200
   VCID: 1D3BC530C4AAEF1
1 Fault Found:
01208 - Data Records in Control Unit Altered
            000 -  -
Address 08: Auto HVAC        Labels: 1K0-907-044.lbl
   Part No SW: 1K0 907 044 BN    HW: 1K0 907 044 BN
   Component: ClimatronicPQ35 110 1010
   Revision: 00110021    Serial number: 00000000000000
   Shop #: WSC 00000 000 00000
   VCID: 74EDC09417A00E9
2 Faults Found:
00819 - High Pressure Sensor (G65)
            009 - Open or Short to Ground - Intermittent
00229 - Refrigerant Pressure
            002 - Lower Limit Exceeded
Address 09: Cent. Elect.        Labels: 3C0-937-049-23-H.lbl
   Part No SW: 1K0 937 049 N    HW: 1K0 937 049 N*
   Component: Bordnetz-SG     H34 0803
   Revision: 00H34000    Serial number: 00000001566415
   Coding: E78F8F0600041828000000001400000000097F075C
   Shop #: WSC 12345 123 12345
   VCID: 3A712EAC7544B89
   Subsystem 1 - Part No: 1K2 955 119 B  Labels: 1KX-955-119.CLB
   Component: Wischer VW350  012  0401
   Coding: 00065493
   Shop #: WSC 12345
   Subsystem 2 - Part No: 1K0 955 559 M  Labels: 1K0-955-559-AF.CLB
   Component: RegenLichtSens 005  0605
   Coding: 00218142
   Shop #: WSC 12345
2 Faults Found:
01049 - Supply Voltage Term 50
            006 - Short to Plus - Intermittent
00987 - Lamp for Brake Light; Left (M9)
            012 - Electrical Fault in Circuit
Address 19: CAN Gateway        Labels: 1K0-907-530.lbl
   Part No SW: 1K0 907 530 E    HW: 1K0 907 951
   Component: Gateway         H11 0110
   Revision: 11          Serial number: 290010531608E7
   Coding: 7FBF074A070003
   VCID: 2953E1E080E2031
3 Faults Found:
01325 - Control Module for Tire Pressure Monitoring (J502)
            004 - No Signal/Communication
             Freeze Frame:
                    Fault Status: 01100100
                    Fault Priority: 2
                    Fault Frequency: 67
                    Reset counter: 56
                    Mileage: 133067 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 09:01:21
00463 - Control Module for Digital Sound Package (J525)
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 254
                    Reset counter: 56
                    Mileage: 133067 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 09:01:25
01044 - Control Module Incorrectly Coded
            000 -  -
             Freeze Frame:
                    Fault Status: 01100000
                    Fault Priority: 1
                    Reset counter: 56
                    Mileage: 133067 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 09:01:25
Address 37: Navigation (J0506)       Labels: 1T0-035-680.clb
   Part No SW: 1T0 035 680 D    HW: 1T0 035 680 B
   Component: RNS-MID       H11 3800
   Revision: AB001001    Serial number: VWZ6Z7K8567923
   Coding: 06000400040000A00000
   ASAM Dataset: ------------------------- ------
   VCID: 2F670FF87E066D1
5 Faults Found:
00857 - CD Changer Unit (R41)
             Freeze Frame:
                    Fault Priority: 5
                    Reset counter: 56
                    Mileage: 133064 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 09:02:24
00821 - Antenna 2 for Radio (R93)
            011 - Open Circuit
             Freeze Frame:
                    Fault Status: 01101011
                    Fault Priority: 5
                    Reset counter: 56
                    Mileage: 133064 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 09:02:34
01299 - Diagnostic Interface for Data Bus (J533)
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 176
                    Mileage: 133067 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 09:02:29
00532 - Supply Voltage B+
            002 - Lower Limit Exceeded - Intermittent
             Freeze Frame:
                    Fault Status: 00100010
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 58
                    Mileage: 134990 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 22:08:09
00446 - Function Limitation due to Under-Voltage
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 58
                    Mileage: 134990 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 22:03:29
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MAX1.lbl
   Part No: 1K0 959 701 G
   Component: Tuersteuergeraet 09 0168
   Coding: 0000054
   VCID: 3261068CAD34409
1 Fault Found:
00943 - Heated Exterior Mirror; Driver Side (Z4)
Address 46: Central Conv.        Labels: 1K0-959-433-MAX.clb
   Part No SW: 1K0 959 433 AR    HW: 1K0 959 433 AR
   Component: 01 KSG PQ35 G2  010 0101
   Revision: 00010000    Serial number: 00000000000000
   Coding: 189002085103087F2D008F0F60085FC690A040
   Shop #: WSC 00717 210 72174
   VCID: 80051C44D318A29
   Part No: 1K0 951 605 C
   Component: LIN BACKUP HORN H02 1301
   Part No: 1K0 907 719 B
   Component: Neigungssensor  004 0003
   Part No: 1K0 951 177 A
   Component: Innenraumueberw.005 0202
1 Fault Found:
00668 - Supply Voltage Terminal 30
             Freeze Frame:
                    Fault Status: 01110010
                    Fault Priority: 4
                    Fault Frequency: 2
                    Reset counter: 18
                    Mileage: 0 km
                    Time Indication: 0
Address 47: Sound System
Cannot be reached
Address 56: Radio (J0506)       Labels: 1T0-035-680.clb
5 Faults Found:
             Freeze Frame:
                    Fault Priority: 5
                    Reset counter: 56
                    Mileage: 133064 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 09:02:24
            011 - Open Circuit
             Freeze Frame:
                    Fault Priority: 5
                    Reset counter: 56
                    Mileage: 133064 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 09:02:34
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 176
                    Mileage: 133067 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 09:02:29
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 58
                    Mileage: 134990 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 22:08:09
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 58
                    Mileage: 134990 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 22:03:29
Address 65: Tire Pressure
Cannot be reached
Address 77: Telephone        Labels: 1K0-035-729-UNI.lbl
   Part No: 1K0 035 729 E
   Component: CIB PAH  HW 202 SW  0308
   Coding: 0000364
   VCID: 2B5F1BE88A1E111
1 Fault Found:
01530 - Radio Mute Switch
End   ---------------------------------------------------------------------
Re: Fault code diagnostic please help out guys!
« Reply #1 on: September 08, 2012, 07:12:48 pm »
I would address the canbus gateway error first "01044 - Control Module Incorrectly Coded".
Did someone with vcds fiddled with your coding in the past or was your canbus gateway changed?
Offline vag12
« Reply #2 on: September 08, 2012, 09:48:00 pm »
Yes once but didnt change anything on the canbus and no hasnt been changed, my main concern is the AC not working with warm air and also the brake light staying on
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #3 on: September 09, 2012, 01:50:25 pm »
I would look under the passenger seat to see if there is a plastic cover and sound system
and I doubt you have the 65 Tire pressure on your car too.
Check the battery as a lot of faults are due to low voltage, then the relay for Terminal 30
Cluster and Key coding
Location Great Yarmouth
Offline Llew
  • -Given: 45
« Reply #4 on: September 12, 2012, 05:22:47 pm »
I had the same problems and it was my battery
Golf 2006 tdi 140pd, dsg paddles,blue interior led lights,r32 rear bumper, cruise control,vcds,highline , r32 mfsw steering wheel, gti front bumper,miltek decat.
Offline vag12
« Reply #5 on: September 13, 2012, 01:09:47 am »
You mean the brake light fault?
Offline Llew
  • -Given: 45
« Reply #6 on: September 13, 2012, 07:55:40 pm »
I meant the same problems with all the fault codes
