Author Topic: Airbag issue - any help?  (Read 647 times)
Offline suave
  • -Given: 31
« on: September 11, 2012, 10:15:18 am »
Folks
I have had a few issues with an airbag warning light which i put down to putting the baby seat in the back and having to move the passenger seat.
Thing is that i have been to a garage this morning and the light wont be switched off - the guy said he had done a fix before and it cost £400!!!!
Does this sound right? Anyone had an issue like this with theirs?
I have MOT today so it will fail as this light is on.
cheers
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
Re: Airbag issue - any help?
« Reply #1 on: September 11, 2012, 10:27:15 am »
is your car 2004 - 2006?
needs the plug cutting out and soldering the wires
where are you located
Cluster and Key coding
Location Great Yarmouth
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #2 on: September 11, 2012, 11:15:51 am »
Offline suave
  • -Given: 31
« Reply #3 on: September 11, 2012, 11:46:20 am »
Thanks Eddie. Just failed mot on the light
Offline Aweful_Truth
« Reply #4 on: September 11, 2012, 11:49:28 am »
I had my air bag light turned off by a local VW specialist non dealer charged me a fiver as i forgot to turn the ignition off when removing the steering wheel airbag, while the light was on as a precaution I did the wire solder and have had no issues since :)
To Bad, So Sad, Bye Bye!
Offline Degudodger
  • -Given: 53
  • -Receive: 86
    • Flickr
« Reply #5 on: September 11, 2012, 01:02:55 pm »
Folks
cheers
If it is a three door the problem is caused by the act of repeatly moving the seat which over time loosens the airbag connector. As Eddie mentioned the two options are to either remove the plug and hard solder the wires together or get a replacement plug and replace it.
Very easy to do but if you give us a hint as to where you are MAYBE somebody will help for the price of a couple of beers :)
