Author Topic: Bought new tts engine cover (with pics)  (Read 16887 times)
Offline Leach76
Re: Bought new tts engine cover (with pics)
« Reply #45 on: October 10, 2012, 01:36:15 pm »
Looks spot on mate :happy2:
Phantom black S3,Giac stage1 & Evoms intake
Offline gazon69
« Reply #46 on: October 10, 2012, 07:00:03 pm »
http://www.audi-sport.net/vb/a3-s3-sportback-8p-chassis/152839-tts-engine-cover.html
"Cover 06F 103 925 H
 Front Bolt: 06E 103 164 E
 Rear Bolts (x2) WHT 000 731A"
That's the part number I have for the front bolt and the rears I have fit perfectly so I'm assuming they were the other part number. :happy2:
Just gave my local Audi dealer the numbers for the bolts. The rear bolt number was fine, but the front bolt number came up on his search as a sump gasket!  Checked the part number twice and came up the same again!!
john, correct part no's are as follows
Rear long bolts are WHT00731A
Small front bolt is   06E103164
Offline taff-turbo
« Reply #47 on: October 10, 2012, 09:49:30 pm »
sorry about that  :ashamed:
but now we have the correct numbers   :drinking:
they fit ok?
« Reply #48 on: October 11, 2012, 12:55:34 am »
Cheers Gaz, I'll try to order again tomorrow. :happy2:
Offline john a
    • The Veneers Cover Band
« Reply #49 on: October 11, 2012, 10:06:10 am »
How do these fit on to the engine? My rear pegs are being used as mounts for the ITG heat shield.
Offline Marshall
« Reply #50 on: October 11, 2012, 10:32:31 am »
You don't use the original mounts mate.
You change 2 of your cam cover bolts for one with pegs on and the cover locates on them.
It does not interfere with any of your itg fitment.
MISANO RED RS3
Offline john a
« Reply #51 on: October 11, 2012, 11:14:17 am »
Lovely job cheers, I'll have a look for a how to - I did check the audisport thread but couldn't find any more info on the process.
Offline Marshall
« Reply #52 on: October 11, 2012, 11:23:19 am »
When you order the cover you order 3 pegs 2 of one style and 1 of another.
The small one screws into the little hole in your inlet manifold and the 2 longer ones go on each side of the cam cover one beside the ting belt cover and the other behind the fuel pump.
Very easy to do and takes 5 mins to do.
Sorry I've not got any pics to help you.
MISANO RED RS3
