Author Topic: handbrake leather fix  (Read 1409 times)
AA
« on: September 13, 2012, 07:27:33 pm »
 My handbrake is covered in cuts scratches and the thread isnt red anymore.Is there a way to replace the leather handbrake cover or do I need a complete handbrake
Offline galaxie500
  • -Given: 38
  • 56 plate 5 door in Black Pearl Metallic
Re: handbrake leather fix
« Reply #1 on: September 17, 2012, 09:39:36 pm »
Hi AA
I believe the handbrake cover is available as a separate part.  It's secured by a little tab that's visible if you pull the lever up as high as it can go; the tab needs a small flathead screwdriver to lever outwards and it will slide off.  The part number should be within.
Good luck!
