Author Topic: Map sensors  (Read 2877 times)
Offline martziniuk
Map sensors
« on: September 14, 2012, 08:57:19 pm »
Hi,
Is the standard GTI map sensor the same as the ED30? or in other words is the K03 sensor the same as the K04?
Re: Map sensors
« Reply #1 on: September 14, 2012, 09:18:48 pm »
Hi,
No, the standard gti has a 2.5 bar sensor and the ed30 a 3.0 bar one.
Offline martziniuk
Re: Map sensors
« Reply #2 on: September 14, 2012, 09:21:38 pm »
Ahh, ive just read they are compatible so it might be a worthwhile buy so I can see the boost pressure over 2.5bar in VCDS.
Offline scopes
  • -Given: 131
  • -Receive: 115
  • Wolfsburg Edition
    • My GTI
Re: Map sensors
« Reply #3 on: September 14, 2012, 09:36:34 pm »
Where did you read that?  :happy2:
Silver is the way !
Re: Map sensors
« Reply #4 on: September 14, 2012, 09:40:15 pm »
Don't do it!   :scared:
Using a 3 bar map sensor on a standard gti or upgraded k04 will give the ecu incorrect readings unless you map is specifically tweaked for this hardware change.
Offline scopes
  • -Given: 131
  • -Receive: 115
  • Wolfsburg Edition
    • My GTI
Re: Map sensors
« Reply #5 on: September 14, 2012, 09:46:22 pm »
As far as im aware it needs the ed30 ecu for the 3 bar map sensor to work
Silver is the way !
Offline martziniuk
Re: Map sensors
« Reply #6 on: September 14, 2012, 09:48:51 pm »
