Author Topic: How will this system sound  (Read 896 times)
Offline dan930
  • -Receive: 56
« on: September 16, 2012, 05:29:22 pm »
Thinking of buying some £200ish 2way speakers for the front,focal to be exact & running oem speakers at the back..will it sound ok or will it be lacking of bass
MK6 golfR dsg
AKS TUNED
NORTECH PERFORMANCE HTA3071
R TECH custom map
Offline john87
  • -Receive: 53
Re: How will this system sound
« Reply #1 on: September 17, 2012, 11:07:11 pm »
It depends if you're running them off a dedicated amp, which will greatly improve their performance. Plus if you want to improve low-end performance and reduce rattles / road noise, then sound-damping your doors is essential also  :happy2: but to answer your question, I'd hope that the Focals would sound better than stock speakers, back-to-back.
Offline jedi-knight83
  • -Receive: 41
« Reply #2 on: September 18, 2012, 12:56:14 am »
As I've found the hard way. If your using a pretty powerful amp then you dont really want to be sending the front speakers anything below about 60-80hz so if you really like your bass then yes you will miss having an amplified sub running 80hz and below.
