Author Topic: Boot Popping..........  (Read 6401 times)
Offline JStav
    • Facebook
Re: Boot Popping..........
« Reply #30 on: December 23, 2012, 07:43:35 pm »
Just fitted all my parts today and got it coded.  Doesn't work  :sad1:
Checked box 3 on byte 2 of the 46 control module and the boot just locks.  The fob couldn't open it and either could the button on the drivers door.
Turn the check box back off and the click save, the boot flies open, but just works as previous.  Absolutely gutted!
Silver GTI, Revo Stage 1, R32 rear bumper, R32 exhaust, R32 rear lights, ED30 front splitter, RCD510, Lowered on Eibachs, open fog grills.
Offline scopes
  • -Given: 131
  • -Receive: 115
  • Wolfsburg Edition
    • My GTI
« Reply #31 on: December 23, 2012, 09:17:18 pm »
Is there a link for the info, on the boot pop. How to code it correctly  :happy2:
Silver is the way !
Offline zerolag
  • Ass of Ennis
« Reply #32 on: December 23, 2012, 09:22:01 pm »
Don't be gutted.
Mine didn't work with the standard VCDS instructions either...  do you have an early version car?
I forget which bits and bytes worked but it's close to above in the same 46 control module.  It will work.
Also, even after it's coded up... it doesn't work great in cold weather.  Pretty hit and miss.
Offline Kalpsn2000
  • -Receive: 56
« Reply #33 on: December 23, 2012, 09:23:04 pm »
That doesn't sound good as I am planning on doing this mod this week.
Offline marko
« Reply #34 on: December 23, 2012, 09:33:28 pm »
yep...ordered up the bits myself today..
 :ashamed: :ashamed:
« Reply #35 on: December 23, 2012, 09:37:04 pm »
Don't be gutted.
As above, you will sort the coding eventually, but its very hit and miss.  :confused:
Could do with stronger struts tbh….although like some have mentioned it will work alot better with the bump stop springs pulled out more.  :wink:
Only trouble with this is, to get my boot to pop every time I need em quite far out. This means when the boot is shut, it doesnt sit flush anymore.  :sad1:
I think Tfsi-Mike mentioned some custom gas struts, you can get made to whatever pressure you want?
Maybe a group-buy is in order?  :laugh:
  • -Receive: 427
« Reply #36 on: December 23, 2012, 09:37:42 pm »
^^^^ We will leave the GB up to you then Carlo! Do like mine (when its warm and "popping")   :grin:
Guide for you Neil (including the coding required via VCDS).......
http://www.ecstuning.com/stage/edoc/MK5RearHatchPop.pdf
« Last Edit: December 23, 2012, 09:40:34 pm by MC71 »
Offline scopes
  • -Given: 131
  • -Receive: 115
  • Wolfsburg Edition
    • My GTI
« Reply #37 on: December 23, 2012, 09:42:27 pm »
thank you !  ^^^^
Silver is the way !
stacy-t-
« Reply #38 on: December 23, 2012, 09:45:47 pm »
I guess I cant just walk into a vw garage then and ask for them to supply and fit this mod then  :pomppomp:
  • -Receive: 427
« Reply #39 on: December 23, 2012, 09:52:19 pm »
^^^^ You can but they will charge you a small fortune! There's a list on here of peeps with VCDS (who are willing to help) and where they live. Get the parts and then contact a member and go from there.
Parts you need and rough prices.....
Boot Pop Kit Part Numbers
2x Skoda Fabia Gas Struts                    6Y0 827 550 D     £35.98 inc Vat for the pair
2x Scirocco (sprung) Pump stops       1K8 827 761 D     £9.89 inc Vat for the pair.
2x Seat Leon Ball pins                           1J6 827 439 A     £11.97 inc Vat for the pair.
VCDS members...
http://www.mk5golfgti.co.uk/forum/index.php/topic,120.0.html
« Last Edit: December 23, 2012, 10:37:46 pm by MC71 »
Offline Kalpsn2000
  • -Receive: 56
« Reply #40 on: December 23, 2012, 10:01:13 pm »
Thats the guide I will be using but JStav has done the same coding as listed in there and it didn't work. Will wait and see what happens when I do it.
stacy-t-
« Reply #41 on: December 23, 2012, 10:04:13 pm »
2x Skoda Fabia Gas Struts                    6Y0 827 550 C      £35.98 inc Vat for the pair
2x Scirocco (sprung) Pump stops       1K8 827 761 D.     £9.89 inc Vat for the pair.
VCDS members...
wow - thank you sir - your service is better than vw lol
I assume everyones keys have the boot symbol in the middle button position,,,, was trying to press it in multiple different ways when I bought the car, thought it must do something lol,,, now I understand.
I will buy the parts on the part numbers you supplied
my car is an 08, does that make a difference and can I fit this myself ?
also any ideas how much I should pay someone for the coding alone
many many thanks to you sir  :pomppomp:
  • -Receive: 427
« Reply #42 on: December 23, 2012, 10:04:59 pm »
Im not sure then,  I had Eddie-NL code mine so not sure if the coding from the ECS Tuning guide is correct or not.
Offline zerolag
  • Ass of Ennis
« Reply #43 on: December 23, 2012, 10:05:38 pm »
Don't be gutted.
TBH, if the cost isn't prohibitive, I may be up for that!
stacy-t-
« Reply #44 on: December 23, 2012, 10:12:19 pm »
VCDS members...
found this but it looks a lot more expensive and also the letter ( D ) on the pump stops is replaced with a (C) is it the same parts ? :pomppomp:
