Author Topic: Glove box handle  (Read 2306 times)
Offline Spooky1
Glove box handle
« on: September 18, 2012, 03:00:49 pm »
Hello,
I have only just realised that my glove box handle is almost broken.
The chrome locking latch bit doesnt like opening because it looks like some oaf (me) pulled on it while it was locked.
I have spoken to the dealer about a possible fix and they replied "its a common fault, the pins used to retain the locks were weak and sometimes break."
The repair kit is a brand new glove box lid with better pins, but a whopping £225 supply and fit.
Does anyone know of a cheaper work around?
ta.
Offline mb
  • -Receive: 29
Re: Glove box handle
« Reply #1 on: September 18, 2012, 03:30:47 pm »
Have you checked eBay as some appear on there
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #2 on: September 18, 2012, 03:32:59 pm »
there is a screw on the inside part of the lid, take that out and the handle can be removed
you can then buy a replacement one for about £8
Cluster and Key coding
Location Great Yarmouth
Offline markymark
« Reply #3 on: September 18, 2012, 03:43:15 pm »
I might have to do this as they put a poxy black one in the Pirelli and I want a silver one!!!
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #4 on: September 18, 2012, 04:12:05 pm »
You can have
Chrome or brushed Ali (both plastic with foil covering)
Offline markymark
« Reply #5 on: September 18, 2012, 04:18:04 pm »
You can have
Brushed ali I think to match the rest of the interior trim. :happy2:
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #6 on: September 18, 2012, 04:21:29 pm »
Brushed Aluminium
Part number is: 1K2 857 147E 3Q7 (£9.30)
Offline Spooky1
« Reply #7 on: September 19, 2012, 11:36:10 am »
Thanks eddie, ill give that a go.  :happy2:
Offline markymark
« Reply #8 on: September 21, 2012, 09:33:05 pm »
Being a complete numpty at these things, I've just tried to remove the old handle but no joy.....what type of screw is holding it in place? Can't seem to get a screw driver small enough into the gap between the lid and the centre console? :ashamed:
Offline mb
  • -Receive: 29
« Reply #9 on: September 22, 2012, 01:47:18 pm »
I think it's a T20 torx
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #10 on: September 22, 2012, 01:51:47 pm »
just be careful the screw doesn't drop inside or you have to take the whole glovebox out to retrieve it
Offline markymark
« Reply #11 on: September 22, 2012, 08:03:30 pm »
Cheers guys, tried a T20 torx driver but it's too long to get in between the centre console and the glovebox. My ratchet set bit is to big to go in the hole in the glovebox lid! What should I be using? :ashamed:
Offline Spooky1
« Reply #12 on: April 01, 2013, 08:35:31 am »
Hello again,
Well I had a go at removing the torx screw, but when I opened the handle to gain access to the screw the handle came clean off in my hand. It was only hanging on by a thread!
So now I guess I'm going to struggle to get the glove box itself open to remove the lid to get the new handle and mechanism in.
Bugger.
Offline skard
  • -Receive: 245
« Reply #13 on: April 01, 2013, 09:33:09 am »
I have a dark grey glovebox in the shed, PM me if interested. I'm overdue a clearout!
Offline Spooky1
« Reply #14 on: April 05, 2013, 08:40:05 pm »
Well Skard sold me his glove box and it is perfect, I have a working glovebox again!
Cheers pal!
