Author Topic: Beamers getting nicked - Discuss!  (Read 1298 times)
Offline scotta
  • Edition 30
« on: September 18, 2012, 09:17:58 pm »
Watched the watchdog report on this last week.
What I want to know if why the alarm didn't go off when they broke the windows?
Nasir
Re: Beamers getting nicked - Discuss!
« Reply #1 on: September 18, 2012, 09:38:19 pm »
The thieves know a weak point in the alarm. Breaking the glass at a certain point does not trigger the alarm. Once the window is broken, hook it up to the obd port, code a new key in. You've just got a BMW.
Offline chungster
Offline mad_pete
« Reply #3 on: September 19, 2012, 11:19:07 am »
technology leaps ahead, nasty crims catch up.
Offline DanGB
  • Different
« Reply #4 on: September 19, 2012, 12:34:56 pm »
But why does the alarm not go off still, is there not a volumetric sensor?
Seat Leon Mk2 TFSI sport 4WD sleeper - Breaking
Buld thread: http://www.mk5golfgti.co.uk/forum/index.php/topic,45377.0.html
« Reply #5 on: September 19, 2012, 12:40:13 pm »
It doesn't go off within about 6" of the door for some reason. One remedy is to move the obd further into the car and a few have had this done.
Offline Moz
« Reply #6 on: September 19, 2012, 01:17:58 pm »
Anyone seen this before?
Going from the comments, appears BMW rolled out a fix to stop the ODB port being used in this way....
Offline TrickGTI
« Reply #7 on: September 19, 2012, 07:10:04 pm »
If that's real then that's shocking how that key codeing happened so quick and easy!!
2006 Tornado red GTI
Offline Neiltdi
  • Full Hex+CAN
« Reply #8 on: September 19, 2012, 07:11:45 pm »
How do the thieves get the key cut to suit the car there going to steal?
Full Hex+CAN in Hampshire.
Offline mad_pete
« Reply #9 on: September 19, 2012, 07:29:48 pm »
It's a proximity key system. No actual key.
Offline perky85
« Reply #10 on: September 19, 2012, 09:11:31 pm »
Blank keys are bought & then coded.
The code is read from the immobiliser system & then forced onto the key, so that when the key is inserted into the slot, the key is recognised by immobiliser & allowd to start.
Rumour has it that the Man behind cracking the system phoned BMW in Munich & asked them if they would like them to go & create the software to stop this  :signLOL:
Offline rtechniki
  • -Receive: 27
« Reply #11 on: September 19, 2012, 09:30:49 pm »
A flaw in the canbus design... The whole can system is live with the ignition off, which allow for key coding
Nick Gower
R-Tech Performance Tuning
Hinckley 01455 617233
Bespoke ECU Software for 1.8T & 2.0TFSI
