Author Topic: Stage 2 bluefin K03  (Read 3828 times)
Offline dave
Stage 2 bluefin K03
« on: September 18, 2012, 09:42:17 pm »
Hi guys i know its been covered before but just really wanting to double check before i buy anything really, fitted an ITG maxogen open filter induction kit aswell as a full TBE decat BCS powervalve system and installed stage 2 and 1st 2nd and 3rd gears it pulls all the way to the redline :happy2: Put it into 4th 5th or 6th though and at about 5krpm it seems to lose power and slow down now it was on stage 1 and never had this bother before!
Is it a case of buying uprated HPFP internals and thats it? or will that need another map from superchips, also is there other things i should be checking.
Just last week i fitted the new revision G diverter valve.
Any help would be great guys
Thanks Dave
Saintsteve
Re: Stage 2 bluefin K03
« Reply #1 on: September 18, 2012, 09:43:39 pm »
get some logs done with VCDS. That will help you find the answer  :happy2:
Offline dave
« Reply #2 on: September 18, 2012, 09:56:43 pm »
you think it would be worth doing the fuel pump internals anyway? week on saturday its going on the rollers so will get it checked over then but was wanting it 100% before then really
Saintsteve
« Reply #3 on: September 18, 2012, 10:18:01 pm »
Rollers and get the diagnosis , or log it to find the fault. KO3 with a SC map should run on stock internals in the fuel pump.
Offline dave
« Reply #4 on: September 18, 2012, 10:24:06 pm »
Okay thanks saintsteve im trying to find someone nearby that has vagcom now and will get some logs done and see whats what
Offline BLUE-STORM
  • GOLF GTI VS CLIO 172 SPORT
« Reply #5 on: September 19, 2012, 05:24:42 pm »
i have the same problem   get in touch mate might be able to solver it together    where abouce are you from  i sent yyou a e-mail  get in touch   , thanks chris
Offline zerolag
  • Ass of Ennis
« Reply #6 on: December 02, 2012, 07:55:56 pm »
I've noticed a definite flat spot / hesitation / fuel cut at ~5kRPM with SC S2 map... it doesn't do it everytime, so I suspect a fuel cut... so probs. HPFP upgrade would solve it.
Love to hear if you get to the bottom of it without any HPFP upgrades.
Offline SL03 JOE
« Reply #7 on: December 02, 2012, 08:25:11 pm »
My mk5 ran bluefin stage II, tbe DECAT BCS exhaust, ITG intake and made 270hp :)
2006, silver, 5 door, top spec, low miles MKV GTI for sale - looking for offers above 9k!
Joe.
Offline BLUE-STORM
« Reply #8 on: December 04, 2012, 01:01:11 pm »
That's what I thought should get. But got problem some where as only getting 203
Offline SL03 JOE
« Reply #9 on: December 06, 2012, 05:21:24 pm »
Will be your DV I reckon mate
Joe.
Offline BLUE-STORM
« Reply #10 on: January 17, 2013, 08:27:03 pm »
im now gettign 266.0
Offline R-tech-Nick
  • -Receive: 30
    • R-Tech Performance Tuning
« Reply #11 on: January 18, 2013, 09:59:39 am »
With a healthy stock hpfp and follower your not going to max it out and get fuel cut with the right mapping.  Running the BWA AXX injectors with the stock pump at 116-119bar on stage 2 is fine.    If your only running the stock rail pressure  behind the injectors then the ecu will end up seeing additive on the fuel trims,  short term fuel trim deviations exceed 15%+ then triggers the initial ecu engine protection by reducing the n75 duty to reduce a little power at the top end.
01455 617233
Offline dave
« Reply #12 on: January 18, 2013, 01:48:04 pm »
Just to add I changed from bluefin to a map by PDT and got 271bhp and 299lbft so I put it down to an incorrect map by bluefin
Offline BLUE-STORM
« Reply #13 on: January 18, 2013, 04:25:32 pm »
that s a difference  , how muich that cost you to change map
