Author Topic: Wheel bolts and spacers  (Read 2168 times)
« on: September 24, 2012, 01:01:22 pm »
I'm presently using 18" Monza 2s on my golf. If I were to use 5mm spacers, would the oem bolts be long enough or would I need to get longer ones?
Offline scopes
  • -Given: 131
  • -Receive: 115
  • Wolfsburg Edition
    • My GTI
Re: Wheel bolts and spacers
« Reply #1 on: September 24, 2012, 01:04:15 pm »
I would have thought you would have needed longer bolts  :happy2:
5mm is 5mm lest of a thread holding your wheels on
Silver is the way !
« Reply #2 on: September 24, 2012, 01:09:35 pm »
Whilst I see your point, do you know what length of thread protrudes from the hub with the standard bolts+Monza combo?
Offline E30Dom
  • -Given: 42
  • -Receive: 76
« Reply #3 on: September 24, 2012, 01:10:46 pm »
Longer bolts on anything 5mm or greater... you should have min of 7 full turns into a hub I was told...
Diesel Daily Hack.
« Reply #4 on: September 24, 2012, 01:13:13 pm »
Ok, so what bolts should I be looking to get?
Offline E30Dom
  • -Given: 42
  • -Receive: 76
« Reply #5 on: September 24, 2012, 01:14:30 pm »
Measure yours and add 5mm, noting whether radiused or tapered... loads of places supply bolts to suit, try dpm performance...
Diesel Daily Hack.
« Reply #6 on: September 24, 2012, 02:01:51 pm »
I would test them first, before splashing out, i reckon you should be close to the originals being long enough. :happy2:
 If you do a search on here for the member,  "The Wheelman'" one of his threads should come up with good info on replacement bolts, sizes.  :smiley:
Offline fab5freddy
  • -Given: 238
  • -Receive: 239
« Reply #7 on: September 24, 2012, 02:45:07 pm »
Standard bolts are 27mm iirc
Offline keano
  • -Given: 79
« Reply #8 on: September 24, 2012, 09:10:57 pm »
My wheel fell off using standard bolts and a 5mm spacer.
£700 down the line I'm still paying for it! Get some extended ones mate :happy2:
Offline vRSAlex
  • -Receive: 253
« Reply #9 on: September 24, 2012, 09:20:07 pm »
Issue with running 5mm spacers is that the wheel doesn't sit on the hub any more and this can cause wheel wobble.  I would always advise running a 10mm hubcentric spacer and longer bolts to suit.
Follow AKS tuning on Facebook
« Reply #10 on: September 24, 2012, 09:23:40 pm »
How can I do away with my 3mm buggers
Offline keano
  • -Given: 79
« Reply #11 on: September 24, 2012, 09:25:01 pm »
Grind your brakes down! Or change wheels! :scared: :scared:
« Reply #12 on: September 24, 2012, 09:26:53 pm »
I'll not have to worry about my bolts not being long enough anymore  :smiley:
« Reply #13 on: October 01, 2012, 01:42:13 pm »
Just to bump this up, if using longer bolts what do folk do about a locking wheel nut?
Offline GNJ_Motorsport
  • -Receive: 20
    • GNJ Motorsport
« Reply #14 on: October 01, 2012, 01:50:34 pm »
We do extended locking bolts and normal bolts mate  :happy2:
0% Interest Free Finance Available On All Parts NOW
www.gnjmotorsport.com
info@gnjmotorsport.com  -  01254 883345
Facebook  -  Instagram
