Author Topic: DV never been changed  (Read 4185 times)
Offline Digger3
« on: September 25, 2012, 08:54:59 pm »
My 2005 GTI which has full history has now done 80k and as never had the DV changed for a revised one
is this necessary if so what's the best revision to go for ?
It's never been mapped,standard 197BHP
Oh and is there anyone in the Brum area happy to do this for some beer-tokens please  :notworthy:
3DR GTI, Black Magic, Factory Fitted Winter-Pack, Lux-Pack, Colour-Coded Rear Valance, Otherwise Totally Standard, For Now.....
Offline Carpy25
Re: DV never been changed
« Reply #1 on: September 25, 2012, 09:09:15 pm »
i,be been told that the latest S3 one is the one to go for better than the forge one I priced one up at about £57 all in from Audi got one trade just under £50 from Audi
part number I used was 06H 145 710 D but please check this first
maybe some old hands can confirm this
Rob
« Reply #2 on: September 25, 2012, 09:10:18 pm »
Your Diverter valve will be the original Diaphragm type. They often split with boost, also with age as it is just rubber type material. Doesn't mean it has split though. If you are going to replace you should use revision D or newer. It is a fiddly job on a KO 3 car, you will need it on a ramp or axle stands at the least.  :happy2:
« Reply #3 on: September 25, 2012, 09:12:10 pm »
Oh and dont waste your money on the fraudge one. not as good, causes its own problems and needs maintenance.  :wink:
Offline Digger3
« Reply #4 on: September 25, 2012, 09:21:04 pm »
OK thanks for the advise.
Being 7 yrs old and the original rubber one, probably best to change it for the revision D
Anyone in the Brum area interested ? or ideas on price with labour, I believe it's AXX engine-code
Offline gigolo456
« Reply #5 on: September 25, 2012, 11:20:58 pm »
The consensus now is for the Revision G, and is cheaper than the D! In R Tech (tuner in Hinckley) it held boost better than the D! IMHO get a remap with them, and according to them to replace the DV is a simple job. Beware thou, its a slippery slope! ;-)
Certainly by all means if somebody here can fit it for u, forget all above (at your peril)! Check on Search for part number for the G, costs about £37 from a dealer!
Offline Tortaruga
  • -Given: 36
  • -Receive: 105
« Reply #6 on: September 25, 2012, 11:22:15 pm »
You could have it removed and inspected. It may be perfect (I checked my 07 recently and it was perfect) in which case you could keep it and spend the money on cocaine.  :smiley:
'07 Red manual
Offline Tortaruga
  • -Given: 36
  • -Receive: 105
« Reply #7 on: September 25, 2012, 11:26:27 pm »
It's not difficult per se, but is fiddly and time consuming.
'07 Red manual
Offline alackofspeed
  • -Receive: 24
« Reply #8 on: September 25, 2012, 11:27:59 pm »
For what it's worth, it's dead easy to change if you've got a standard undertray. If the car was parked with the right handside on a kerb and you're not a portly squire, you could easily crawl under, reach up the back of the engine and change. Can be done in a matter of minutes.
Offline Hogster
« Reply #9 on: September 25, 2012, 11:28:35 pm »
 :signLOL: :signLOL:
Offline Tortaruga
  • -Given: 36
  • -Receive: 105
« Reply #10 on: September 25, 2012, 11:38:33 pm »
Have you tried it? I had mine on ramps and it took about 45 minutes. Perhaps in mitigation it was because it was my first time (fnarr). I found the working room limited and I was also working blind to remove/replace the top bolt.
'07 Red manual
Offline sub39h
  • -Given: 189
  • -Receive: 84
« Reply #11 on: September 25, 2012, 11:39:52 pm »
I'd give Midland VW in Cannock a bell. They'll sort it for you for a reasonable price. Jody (the gaffer) does tend to prefer the rev D tho but if you ask for the G they'll fit it for you no probs.
PLANS: Stage 2+
  • -Receive: 427
« Reply #12 on: September 26, 2012, 06:41:14 am »
I would go with the Revision G. If you do go for the D, I believe there is a new one without a cage (not sure what's it is actually called) around the end, seen it mentioned on here slew here.
Offline homesqueeze
  • -Given: 32
  • -Receive: 43
  • Got another Golf!
« Reply #13 on: September 26, 2012, 12:40:04 pm »
Call me stupid, but what is a diverter valve?  :drool:  Keep hearing people on here talking about them, but I have no idea what it is. I have had my 05 GTI (unmodded) from new and never had anything done to mine. What difference do the revision ones make? Are they simply more durable or do they actually have some performance improvement?
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
« Reply #14 on: September 26, 2012, 12:58:17 pm »
The diverter valve cuts off the flow of boost to your engine when you lift off the throttle, and recirculates the air back round the system to reduce turbo lag when you plant your foot again. Its a small part that sits on the side of the turbo.
The newer revisions are more durable than their predecessors (early ones are very prone to splitting and leaking boost), no performance improvement with the newer ones :happy2:
