Author Topic: Drive shaft came adrift  (Read 1067 times)
mbjackson55
« on: September 26, 2012, 02:24:41 pm »
My 6 year old MK5 GTI came to a grinding and crunching halt this week, fortunately in a side street at 5 mph.
It seems that the nearside drive shaft had come away from the gearbox. The flange bolts were missing and there was gearbox oil all over the road.
The gearbox is damaged and the repair job is quoted at over £4k.
Previously the car had suffered a failure to an engine mount bolt as a result of the garage reusing the original bolt instead of a new one after a cam belt change.
Some questions....
Anyone ever experienced anything like this?
Any way the two events might be related?
any thought appreciated
Saintsteve
Re: Drive shaft came adrift
« Reply #1 on: September 26, 2012, 04:17:56 pm »
I would question the repair work as not being installed or torqued correctly..
Driveshaft failure on the GTi...well it's one of the 1st I've read about in 4 years of being a forumite.
Offline alackofspeed
  • -Receive: 24
« Reply #2 on: September 26, 2012, 07:48:45 pm »
The correct procedure to remove the cambelt involves unbolting the driveshafts. This is to avoid articulation damage when shunting the engine about to get full access to the belt.
