Author Topic: MK5 ECU info required  (Read 1296 times)
Offline GLIDN
« on: September 28, 2012, 06:01:36 am »
Ok, what I am interested in know is the following.
I want to swap my ECU from my MK5 into another MK5.
Back in the MK4, you simply swapped ECU's then just READ the ECU from the Cluster login with VCDS to activate the ECU.
Now I'm wondering if this is possible to do in the MK5 cars? or is the IMMO encryption stuck in the ECU and the Cluster now?
For some reason I'm thinking it's only cluster. Well on early mk5's so basically Immo4 or Immo4c.
MODS : Sorry was not sure if Performance Area, technical Area or VCDS area applies for this question.
Offline PDT
  • -Receive: 142
Re: MK5 ECU info required
« Reply #1 on: September 28, 2012, 10:49:17 pm »
Are the hardware and software numbers the same? (HW number starts with 028)
If so I can make a backup copy and clone it to the other ECU.
Offline GLIDN
« Reply #2 on: September 29, 2012, 07:43:41 am »
Not sure if the Hardware and software coding is the same just yet. As they are the same engine and same year I can only assume so.
It will be great if you could do this, however I'm over in New Zealand. None the less if you can please PM me your details then we can discuss this further.
Offline PDT
  • -Receive: 142
« Reply #3 on: September 29, 2012, 09:09:44 pm »
When you have photos of both ecus post them  :happy2:
Offline kalu
« Reply #4 on: September 29, 2012, 11:44:15 pm »
It's possible to adapt it by OBD, you just need both pin codes. (new and old)
Offline GLIDN
« Reply #5 on: October 01, 2012, 12:52:43 am »
thanks Kalu, I believe you are the man for all cluster coding etc too?
Will have to have a chat to you about this one.
PDT - Will dod when I get a chance.
