Author Topic: 2 tyre questions  (Read 1157 times)
Offline Tortaruga
  • -Given: 36
  • -Receive: 105
2 tyre questions
« on: September 29, 2012, 12:15:06 am »
OSR tyre not holding pressure; drops off gradually and needs pumped every couple of weeks.
Can anyone advise me where to start? Valve I suppose?
Also, part worn tyres...anyone fitted these or should I have my head examined?
Thanks in advance.
PJ
'07 Red manual
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=uhdngqst1i18olts5pucrd6ljk&/topic,19740.0.html
Re: 2 tyre questions
« Reply #1 on: September 29, 2012, 12:44:32 am »
Valve checked.
Submerse tyre and wheel in a big drum of water and check for leaks.
Dont be a tight arse and buy new tyres.... they are the only thing that it keeping you on the road!
« Reply #2 on: September 29, 2012, 07:58:50 am »
I've bought part worms but only from a source I trust.
If you go to a decent tyre shop they will probably investigate your slow puncture by removing the tyre and refitting a new valve. No puncture no fee.
Offline Matto
  • -Receive: 116
« Reply #3 on: September 29, 2012, 08:21:44 am »
If not the tyre or valve it can be caused by corrosion on the seating surface inside the wheel. I had this on my old mk4. Tyre place dressed them up and it stopped losing pressure.
Offline chippy
« Reply #4 on: September 29, 2012, 08:51:09 am »
Same problem i had. but was found to be a small nail causing air leak. new tyres no problems. also have nitrogen in all 4 and thats supposed to be better.
