Author Topic: very noisy fan / belt / something with engine running or just ignition on  (Read 1105 times)
Offline Timmyb007
As above
Very noisy with just ignition on and for a while after engine has been running and ignition turned off. Other problem was judder after switching engine off but have since decided this is unrelated - see below
Thank
Tim
« Last Edit: October 03, 2012, 06:02:36 pm by Timmyb007 »
Offline skard
  • -Receive: 245
Re: Sometimes lumpy at the point engine is switched off / very noisy fan
« Reply #1 on: October 03, 2012, 04:33:32 pm »
Do you have a diesel?
Sounds like the inlet manifold flap motor, sits just before the EGR.
Shares a circuit with the fans too.
Recently replaced mine, was £147 after discount from ECP for same part VW supply (wrongly listed as throttle body)
Offline Timmyb007
« Reply #2 on: October 03, 2012, 05:06:10 pm »
Hi yes its a diesel. I think the noise is there whilst driving more much more noticeable when engine off. Sounded like amplified turkey gobble! Haha any suggestions on how to narrow down what it is? Did your do it even with engine off?
Offline skard
  • -Receive: 245
« Reply #3 on: October 03, 2012, 05:09:14 pm »
These might be seperate issues.
Best bet is to get a VCDS scan.
However, my 'flap' never came up as a fault even though it wasn't functioning, it was when I took it out to clean I noticed it was solid. Replaced it and it turns off super smooth now.
Offline Timmyb007
« Reply #4 on: October 03, 2012, 05:18:06 pm »
I think you maybe right.
The main issue being the fan / belt noise. My wife encountered it today so ill take a look when I get home. And ill get that flap cleaned at next service.
Offline skard
  • -Receive: 245
« Reply #5 on: October 03, 2012, 05:22:53 pm »
You can check function of the flap easily.
With engine off, undo the big black hose going into motor (front of engine, prise off clip with flat screwdriver) and see if you can push the flap inside, if it is difficult or won't budge it's likely seized open.
It's function is to close for a few seconds when the ignition is killed, then remains open, and allows for a smooth turn off.
Offline Timmyb007
« Reply #6 on: October 05, 2012, 10:47:53 pm »
It was exactly this in the end!! Got one from ECP as well, just got to fit it now.
